23851 Discussions
Intel(R) HD Graphics 3000 - No Signal
I'm trying to connect a ViewSonic VX2235WM to my new Intel HD 3000 video card using DVI and I get No Signal, if I leave everything the same but just replace the monitor with a Samsung SyncMaster 2233sw everythign works just fine.
While the Viewsonic Monitor is connected to a working computer Moninfo outputs:
Monitor
Model name............... VX2235wm-3
Manufacturer............. ViewSonic
Plug and Play ID......... VSCBA1E
Serial number............ QCZ070403165
Manufacture date......... 2007, ISO week 4
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 470 x 300 mm (22.0 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Not supported
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.646 - Ry 0.339
Green chromaticity....... Gx 0.290 - Gy 0.603
Blue chromaticity........ Bx 0.145 - By 0.065
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-82kHz
Vertical scan range...... 50-75Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1680x1050p at 60Hz (16:10)
Modeline............... "1680x1050" 146.250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1680 x 1050p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1400 x 1050p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
640 x 400p at 70Hz - VESA STD
Raw data
00,FF,FF,FF,FF,FF,FF,00,5A,63,1E,BA,01,01,01,01,04,11,01,03,80,2F,1E,78,2E,75,35,A5,56,4A,9A,25,
10,50,54,BF,EF,80,B3,00,A9,40,95,00,90,40,81,80,81,40,71,4F,31,0A,21,39,90,30,62,1A,27,40,68,B0,
36,00,DA,28,11,00,00,1C,00,00,00,FF,00,51,43,5A,30,37,30,34,30,33,31,36,35,0A,00,00,00,FD,00,32,
4B,1E,52,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,56,58,32,32,33,35,77,6D,2D,33,0A,20,20,00,8F
If I connect the monitor using VGA it works.
Any ideas what it's causing this issue?
I'm using driver version 8.15.10.2761 .
Thank you.
