23854 Discussions
HD Graphics 4000 drop fps
I currently have an i5-3570k on a Z77 Gigabyte MB.
I have the gpu frequency to the top (3200) and the CPU running at 42 clock ratio
When I start a game its FPS are between 55-62 but suddenly as the game goes by it drops until 30-36 and won't go higher no matter what.
I was wondering if this is a problem or is normal.
I'm running under Wine on Linux.
NICHOLAS_F_Intel
Hi Alex,
What game(s) are you experiencing this FPS drop with? Your system might be overheating as well - does it crash after extended play-times? Unfortunately, since you are running Linux*, I'm not able to provide any in depth insight to the issue as our driver is not supported on that OS. However, I can refer you to the Intel® Linux* community website here; https://01.org/linuxgraphics/community Community | Linux Graphics
-Nic
