23832 Discussions
HD Graphics 4000 performance issues with OpenGL - Windows
I am experiencing performance issues when running an OpenGL application with the Intel HD Graphics 4000.
System properties:
Motherboard: Intel DH77DF
BIOS: KCH7710H.86A.0103.2012.1029.1732
CPU: Core i7-3770S (8M Cache, 3.10 GHz)
Memory: 16 GB
Memory speed: 1600 MHz
OS: Windows 7 Professional SP1 64-bit
GPU: Intel HD Graphics 4000
Graphics driver version: 9.17.10.2875
Video BIOS: 2143.0
Display resolution: 1920x1080
Refresh rate: 60p Hz
The application consists in displaying images in a window either at the highest frame rate possible or at 60 fps with vsync on.
Here are some frame rate results with vsync off:
-window size of 480x270: ~2000 fps
-window size of 960x540: ~300 fps
-window size of 960x1080: ~145 fps
-full screen window: ~65 fps
And these are results with vsync on:
-window size of 480x270: ~32 fps
-window size of 960x540: ~60 fps
-window size of 960x1080: ~59.5 fps
-full screen window: ~59 fps
Running two instances of this same test application causes the performance figures to drop to the following (vsync off):
-window size of 480x270: varies between 500 and 1500 fps
-window size of 960x540: ~140 fps
-window size of 960x1080: ~62 fps
-full screen windows: ~30 fps
With two instances and vsync on:
-window size of 480x270: ~58 fps
-window size of 960x540: ~58 fps
-window size of 960x1080: ~50 fps
Something is clearly wrong when vsync is on and there seems to be a very high performance drop when vsync is off and the window size is increased.
Can anybody help on this?
Cheers,
e_dod_as
NICHOLAS_F_Intel
Hi e_dod_as,
What OpenGL application are you referring to specifically?
-Nic
It's an application I have developed, I can send it to you if you want.
Below is an e-mail I received from Intel support regarding this issue. I hope it helps (the date of the e-mail is Dec 19 2012).
Hello Barry,
Thank you for contacting Intel Customer Support.
I understand you need information about OpenGL* support on the Intel® HD Graphics 4000.
The Intel® HD Graphics 4000 supports OpenGL* 4.0, you need the latest Intel(R) Graphics Driver to enable this feature.
If you are interested in additional information about the graphics controller see here: http://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics http://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics
Sincerely,
Allan
