23654 Discussions
HD Graphics 530 drivers for Windows 7
EGlen1
Hello.
I have a problem with Intel HD Graphics 530 drivers for Windows 7 which integrated in Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz. i've tried to install driver ver 15.60, 15.45, 15.40 with 6Gen CPU capability from https://downloadcenter.intel.com/ Drivers & Software , but nothing changes. Driver don't works. Max resolution 1366*768. OS cannot calculate Windows Experience Index. DirectX tests unavailable.
Stefan3D
When you say "Driver don't works" do you mean that installation failed?
Visit https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530 Downloads for Intel® HD Graphics 530 again.
Select OS from right pull-down menu (you tried a 15.60 driver, that is Windows 10 exlusive)
Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
EGlen1
I tried 15.40 driver. I used your method, but I got the same problem. Everybody says Intel HD graphics in SkyLake CPU don't work correctly in Windows 7. On screenshot you can see OS frothen and cannot complite raiting.
n_scott_pearson
Actually, the recommended drivers for Skylake are 15.45. The latest available version for Windows 7 x64 is 15.45.23.4860. This is what I am running on my Skylake-equipped Intel NUC systems.
Hope this helps,
EGlen1
I installed 15.45.23.4860. OS shows driver version 21.20.16.4860. Same problems
