23806 Discussions
HD3000 HDTV problem
HUysu
Hello! I hooked up my Laptop to my Insignia TV. However every time I switch to my Ps3 (HDMI2) and back to PC(HDMI1) the screen resets. The screen goes grey and fuzzy (Grey noise?) occasionally as well. The brightness defaults and I have to change it in the settings on the TV. Now I would've thought it's a problem with the TV however I saw that the TV's brightness and other settings stay the same when the brightness for example goes up. I also exchanged it for a new one. Tried four different HDMI cables as well. I also only get Maintain display scaling on 1360x768 and 1980x1080. I get the best quality on 1360x768 with Maintain display scaling. I tried other resolutions and scaling types and still got the same problem and the screen didn't look right . Thanks !
Current setting: -maintain display scaling at 1360x768 (which is recommended),32Bit,59HZ refresh rate.
my PC:Asus K53SV laptop second generation I5 procesor with intel HD3000.
-Graphic card driver version 9.17.10.3062
-Windows 7 Service pack 1
TV: 720P 28" Insignia TV
DArce
Valued Contributor III
Please post the dxdiag report from that system and the graphics report generated by the graphics controller as illustrated here:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics | Intel(R) Graphics Driver Report
HUysu
Intel(R) HD Graphics 3000
Report Date: 7/29/2013
Report Time[hh:mm:ss]: 14:30:35
Driver Version: 9.17.10.3062
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 8102 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2111.0
Current Graphics Mode: 1360 by 768
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
Non Active Notebook Displays: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 24.02 inches
Vertical: 13.78 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (56 Hz)
1024 by 768 (60 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 768 (60 Hz)
1280 by 720 (60 Hz)
1280 by 800 (60 Hz)
1280 by 800 (75 Hz)
1360 by 768 (60 Hz)
1440 by 900 (60 Hz)
1680 by 1050 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 08 59 41 28 01 01 01 01
00 17 01 03 80 3D 23 78 0A 67 BD 9C 55 57 9B 28
10 47 4A A3 08 00 81 C0 81 00 81 0F 81 40 95 00
B3 00 81 80 01 01 66 21 50 B0 51 00 1B 30 40 70
36 00 5F 59 21 00 00 1E A9 1A 00 A0 50 00 16 30
30 20 37 00 5F 59 21 00 00 1A 00 00 00 FC 00 4E
53 2D 32 38 45 32 30 30 4E 41 31 34 00 00 00 FD
00 17 4C 0F 51 0F 00 0A 20 20 20 20 20 20 01 D6
02 03 20 71 4A 01 02 03 84 05 06 07 20 10 22 26
09 07 07 15 07 50 66 03 0C 00 10 00 80 E2 00 0F
02 3A 80 18 71 38 2D 40 58 2C 45 00 5F 59 21 00
00 1E 01 1D 80 18 71 1C 16 20 58 2C 25 00 5F 59
21 00 00 9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00
5F 59 21 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E
96 00 5F 59 21 00 00 18 8C 0A A0 14 51 F0 16 00
26 7C 43 00 5F 59 21 00 00 98 00 00 00 00 00 86
* Built-in Display *
Gamma Value: 2.2
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 07.48 inches
1366 by 768 (60 Hz)
* Other names and brands are the property of their respective owners. *
DArce
From what I can see in that report 1680 by 1050 (60 Hz) is the highest video resolution native supported by the monitoring you are using. In such case, the issue might be related to using unsupported Video Modes in that external display
HUysu
I changed it to 1680x1050 (60HZ) however I still encountered the same problem. Letters and other items we're way too small as well. 1360x768 is recommended on the resolution screen. What could be the problem? I really don't want to buy a new TV just because of my graphic card. Thanks for your help by the way
DArce
In fact checking the specifications of the TV the maximum resolution that should be used is 1366 x 768, using any video resolution higher than that you result on loosing video quality and could damage the TV. I suggest you try a truly 1080p display to test.
HUysu
Im using 1360*768 anyway. I think I may have found the solution though but it's a guess. Could it be power management support? I read-
Maybe I need to find a way to support them? Maybe that's why the settings default and I get grey screen?
DArce
These settings depend from what the EDID of the monitor claim that the monitor is able to support. If these settings are marked as not supported possibly they are not, or the EDID from the display does not provide this information. That could happen if you are using an old display or a display with incorrect EDID
Try using a display that clearly states that supports 1080 in order to troubleshoot this issue.
