22884 Discussions
MOHAA BreakThrough is not running on Intel 4000
ZKhan4
I got Acer E1-571 with Intel HD Graphics 4000 and MOHAA is not running on my machine...... People suggest many things but nothing worked......... last thing i did was copied OpenGL32.dll to my Mohaa main folder and now i am getting this error
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' 😞 succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created mailto:window@0,0 window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 24, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Kindly explain how to run this game
DArce
Valued Contributor III
What is the driver version being used and the os installed?
Please test the game with no mods installed or custom configurations like the one you mentioned above and then use the latest patch or update provided by the game developer.
ZKhan4
Dear Diego,
First of all, thank you very much for your prompt reply.
I am using
Windows 7 Ultimate - 32 bit OS
Acer Aspire E1-571
Intel Core i3-3120M mailto:CPU@2.50GHz CPU@2.50GHz
RAM 8 GB
Driver Version 9.18.10.3165
Driver Date 5/7/2013
DirectX9 (as recommended by most of the MOHAA players)
I tried to run fresh MOHAA without any add-ons or modifications but that didn't work.
Kindly assist.
DArce
Let me check further on this and get back to you as this might be a compatibility problem.
DArce
Please check the troubleshooting information that is available on the following URL and post the information that is required there.
http://www.intel.com/support/graphics/sb/CS-033945.htm http://www.intel.com/support/graphics/sb/CS-033945.htm
Also, be sure to be using the latest updates for this game.
MSchm21
Does it work what he wrote?
