- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
This has been reported by several other users http://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/intel-hd-4000-drivers-cause-black-screen-in/f93e2b93-8a33-4448-bf77-3ce1e067b5a8?page=2 http://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/intel-hd-4000-drivers-cause-black-screen-in/f93e2b9…
who share two main characteristics:
A - They are using 3rd gen cpu and the corresponding driver
B - They were able to install the original Windows 10 release (15240) without issues, so the black screen is specific to TH2 and later versions (in my case it would be RS1 available to insiders)
It is still not working with the latest 3rd gen driver 15.33.43.4425 https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33- Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33] . From the driver notes it seems that this series has yet to be tested with TH2, so that might explain things.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello, prusswan:
Thank you for letting us know about this situation.
In order to further support this, please provide me with the Intel® System Support Utility report from your system.
How to get that report?
-Access: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
-Download the utility
-Scan your system with the utility
-Export the report and attach it to your answer with the advanced editor option
Esteban C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello, prusswan:
So we have a laptop with Intel HD Graphics 4000
It has the same Windows 10* release (10240), I installed the driver 4425, played some videos and regular use of a PC, didn't receive a black screen.
Is there any specific task you perform which triggers the issue?
Please let me know.
Additionally, added some screenshots and the SSU report from the device used, this can be opened with the Intel® System Support Utility
Hope I can hear from you soon and positively.
Configuration before the tests:
Configuration while performing the tests:
Esteban C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The problem is NOT with the original release of 10240.
It is a problem with
http://www.askvg.com/fix-windows-10-november-update-threshold-2-not-showing-on-your-computer/ Windows 10 November Update (Threshold 2)
this is also known as the 1511 (November 11th) or 10586 update
Another person with a similar issue:
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am having the same or at least similar problem. I am on build 14393.105 and have Intel HD 4000 graphics (as well as Nvidia Geforce GT 620M). My laptop's built-in LCD screen no longer displays video output. The backlight is on, but the screen is black, even during the boot process. I can only get output via HDMI. I have tried reinstalling drivers for both video cards and of course, switching between displays, etc. I hope it is not a hardware problem but it seems like it probably is. Any help appreciated. Thanks.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello, dlwn83 :
I am sorry to hear you are having this issue.
Please try the following (with external display connected via HDMI):
1. Disable the Nvidia GPU, this can be done in the device manager, right click and disable.
2. Do as in step 1 but with Nvidia GPU active, disable Intel GPU
3. Remove all the drivers and let Windows 10* load default drivers.
If you don't get any image with those configurations, this is probably a HW issue. Possible drivers issue would be checked with these configurations, for that reason, we can say it may be a hardware issue.
Hope this can help you to get a better overview of the scenario you are facing.
Esteban C
