23279 Discussions
HD4600 UHD Displayport MST
safas
Hi!
I have a Panasonic TX-65AXW804 UHD TV and I connected it via displayport to my pc.
The problem is that with UHD (3840x2160) resolution I can only select 60Hz. But the TV can also 24Hz and so on.
At 1920x1080 I can select all refresh modes but the TV stays black.
When I switch the displayport to SST on the TV side, I can select all modes correctly according to the specs:
All FullHD modes and UHD at 30Hz (maximum for single stream) and it works.
With older drivers, the PC show me the TV as 2 different Monitors.
So it looks like the driver dont detect the TV correctly in MST mode.
Allan_J_Intel1
Thanks for joining the Graphics community.
Please check this post for similar information about this matter:
Allan.
safas
Noup. Its not the same problem. 3840x2160@60Hz IS working correctly! LOWER freuqencies are not available. Thats my problem!
The other problem is that all 1920x1080 modes not working correctly (Screen stays black, wrong signal). With older driver they are working correctly
(1080p60/50/24).
ROBERT_U_Intel
@ Seppdog, could you please provide the full EDID data from your display? You can use a tool such as the free one provided by EnTech found here:
http://www.entechtaiwan.com/util/moninfo.shtm EnTech Taiwan | Utilities | Monitor Asset Manager
Robert
safas
Here we go...
kind regards
Seppdog
ROBERT_U_Intel
Thanks Seppdog, we are continuing to investigate the issue.
Robert
safas
New driver, same problem...
Why is it so hard to fix a simple EDID problem!?
My old notebook with Ivybridge gets the correct information from the TV. With the complete same setup.
I dont understand this....
ROBERT_U_Intel
Hi Seppdog
We are still investigating the issue. I will update this thread when I have additional updates.
Robert
ROBERT_U_Intel
Hi Seppdog
For some reason the EDID you posted was truncated. Could you try this please? Open a Command Prompt window and run "dispdiag" and post the data file created here. I will be able to get full EDID info from it.
Robert
safas
hopefully the file is ok
safas
Sorry. I have send you the diag while HDMI was active.
now witch DP...
ROBERT_U_Intel
safas
Hi!
I'am waitng now for more than one year!!! for a solution!
At the moment I have the latest hd graphigcs driver installed, but I have always the same problem:
Via Displayport MST I can not show 4k content in all refreshrates (60p/50p/24p). Its definitely a EDID problem.
How long I have to wait for a correct working driver?
kind regards
safas
safas
Is there nobody out there who is using 4k via DP with a TV?
Bryce__Intel
Hi Seppdog
The Debug Engineer is asking for some info let me know what the result is. Pass/Fail - Same/Different
  1. Use current release driver on Intel.com (15.36 4332 as of 4/14/16)
  2. Connect only the 4k TV in MST mode
  3. Check both CUI and OS Display Properties to see if 3840x2160 23\24Hz are missing
  4. Recapture Dispdiag logs
  5. Check if there are any firmware updates for their TV on the manufacturer's websites.
safas
This is not possible with this driver.
The screen stays black.
Bryce__Intel
Which number are you responding to?
safas
I cant do the testing procedure.
I have installed the .4332 driver, switched the TV to Displayport MST and the TV stays black.
So, I dont know if the 24p option is missing on CUI and OS and also I cant send you the dispdiag logs...
If you mean the message number: 15
Bryce__Intel
Thanks, is there a newer firmware for the television? Which are you currently using?
Do you have two DP cables plugged in to support MST?
safas
Noup. The latest firmware is used: version 3.128.
I use one DP cable.
