22656 Discussions
HD4600 driver does not detect HDCP support in my AV processor
cshon
System:
Intel Core i5-4670T(2.30GHz) HD4600 graphics
ASRock Z87E-ITX motherboard
8Gb RAM
Windows 8.1
I have the above HTPC (latest Intel divers) connected to a Merdian HD621 audio processor leading to a Pioneeer LCD diaplay
The Merdian HD621 and display are both HDCP compliant and I have other blu-ray players going though the system with no problems.
In the HDMI properties of my HTPC, however the Inel driver indicates 'HDCP not supported' so I can't play blu-rays via my HTPC.
I've tried different HDMI cables etc.
Any suggestions as to what the issue could be?
Kevin_M_Intel
Hi Madscientist,
I am sorry to hear you are having problems with this configuration but let me help you.
Can you please confirm if you are using a direct connection between the devices (no adapters)? If you are using video adapters, have you checked if are HDPC compliant? Can you also post your dxdiag report here?
JBouc3
I am having this same issue.
Just switched over from a dedicated gpu so that I would be consuming less power only to find out intel 4600HD graphics has a severe HDCP bug.
My system: gigabyte z87-ds3h with 8gb ram, i7-4770k cpu, win7 x64 professional, ceton infinitv6 for cable card tuning and hauppaugge 2250 for ota tuning. The HTPC is connected to my onkyo TX-SR805 via hdmi and then hdmi to my Samsung lcd tv. The issue Is with windows media center playback of copy protected material. I have no issue with blu-ray playback just protected cable channel playback.
JBouc3
Here's my dxdiag from this issue:
System Information
Time of this report: 4/13/2014, 13:44:55
Machine name: HTPC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z87-DS3H
BIOS: BIOS Date: 09/24/13 16:35:13 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 8192MB RAM
Available OS Memory: 7880MB RAM
Page File: 1547MB used, 14212MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_D0001458&REV_06
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: TX-SR805
Monitor Id: ONK0781
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3496 (English)
Driver Version: 10.18.10.3496
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/7/2014 09:21:58, 26168168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-407A-0AF0BBC2C735}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0xD0001458
Revision ID: 0x0006
Driver Strong Name: oem13.inf:IntelGfx.NTamd64.6.1:iHSWD_w7:10.18.10.3496:pci\ven_8086&dev_0412
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Bac...
JBouc3
Today an extremely knowledgeable cable tech came to my house to do some troubleshooting. He informed me that SDV channels have different mpeg encoding so that they don't take up as much bandwidth. So from what I understand from this is that for some reason intel's hd 4600 graphics solution has a problem with mpeg4 encoding. Mpeg 2 seems alright, besides for some really annoying video flickering.
In the end it is not an HDCP/hdmi cable spec issue, it's a driver issue.
Kevin_M_Intel
JBouc3
Yeah, I figured this out yesterday when the cable tech came by. We had a discussion concerning SDV and how SDV channels are encoded in mpeg4...... Therefor making intel onboard graphics completely impossible for HTPC builds. I'll have to find a lower power fanless graphics card to reduce my power consumption and lower the sound output of the unit. Asus' gt630 should do the trick.
Thank you for the response.
Kevin_M_Intel
ctren
Im having the same issue on a Toshiba laptop with an HD 4600 and Win 8.1. My directv app says it will not allow playback, the driver does not prevent screen capture for protected content.
I just bought the laptop today, updated the video drivers as told by directv and no change. So are your saying this hardware will never allow playback of this content ? If so I will return this laptop now before I loose any packaging and find one with an amd video chipset.
PGlow
I have a similar problem:
If I understand correctly, intel develops HDCP which is not downwardly compatible and we bought new, but already outdated intel hardware??? And even if I buy new Intel hardware, what happens with the release of the next HDCP version???
Kevin_M_Intel
Well, depending on the graphics controller you can get support for HDCP. Nowadays, our graphics controller HD 4600 or 4th generation supports up to HDCP 2.1 so I regret to say that this may be a hardware limitation.
PGlow
Hallo kevin_intel, thanks for replying to my post.
Before I buy new hardware, is there a way to diagnose the problem and to find the weakest link in the chain (regarding HDCP version) or at least to check the supported HDCP version of my HD4000? Theoretically, it might be a hardware bug or some incorrect sent signal as well(?).
Moreover, is there some official/general FAQ regarding HDCP, that is, how to cope with HDCP when buying new hardware, can I, in the future, update the HDCP version current hardware with a new firmware? For example, I buy a new TV supporting HDCP 2.1 and everything compatible, that's fine. But after releasing HDCP 2.2 I get a new blueray player and I'm forced to buy new hardware or at least to wait until I get corresponding HDCP updates for ALL hardware. And if even one manufacturer does not deliver, I got the weak link in my HDCP chain and the problem starts again.
So you see, for me it's just not the current problem, but I am really at loss here how to cope with this issue in the future...
JBouc3
Guys it's not an HDCP issue. It's simply that intel's graphics solution doesn't support playback of mpeg4 streaming video, which unfortunately is what the cable companies are turning to freeup intranet bandwidth.
PGlow
Hey Jonny80s,
in my case it's a HDCP problem, since I get an HDCP error when streaming Amazon Instant using Silverlight. I crossposted here and linked my question since I didn't get any support in the other thread and here an (assumed similar) HDCP problem was discussed.
Thx anyway
Kevin_M_Intel
Glowallp,
The HDCP support is at the hardware level. The software will make the transition to make the hardware work fine but in the case that the driver supports higher versions the hardware will still support HDCP 2.1.
GSeri
You seem to restate the same response over and over. Can you suggest a solution? I have the same issue with my i7-3770K with an LG BH12LS38 Internal SATA Blu-Ray Drive. I can't play blu-ray. It is not the cable and not the monitor. The drivers do not support HDCP. I need a driver that supports HDCP and it doesn't seem appropriate suggest trying different hardware combinations or install a graphic card and stop using HD4000.
