23088 Discussions
HD4600 resolution problem with HP LA2405x monitor
RHend4
I'm having trouble with Intel HD4600 driving an HP LA2405x, and limiting the top resolution to 1920 x 1080.
The monitor's native resolution is 1920x1200.
Is this a bug? It looks like one as the mode is explicitly listed.
custommodeapp complains that the bandwidth is exceeded. Which makes it unhelpful. I guess it is making the same mistake as the main resolution utility.
The monitor information says:
Intel(R) HD Graphics 4600
Report Date: 12/6/2013
Report Time[hh:mm:ss]: 15:12:07
Driver Version: 9.18.10.3204
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United Kingdom)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
Physical Memory: 8097 MB
Processor: Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz
Processor Speed: 2693 MHz
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
Video BIOS: 2171.10
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: HP Compaq LA2405x LED Backlit Monitor
Display Type: Analog
Connector Type: VGA
Serial Number: HWP3020
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Monitor
Maximum Image Size:
Horizontal: 20.47 inches
Vertical: 12.60 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
800 by 600 (60 Hz)
1024 by 768 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 960 (60 Hz)
1440 by 900 (60 Hz)
1600 by 1200 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1200 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode...
Kevin_M_Intel
This question has been responded at the following link:
/thread/47065 https://communities.intel.com/thread/47065
