23526 Discussions
HD5500 Linux can't enable 3840x2160@60hz
MBake2
Hello.
I have a Philips Brilliance 288P monitor, which should support 3840x2160@60hz.
My laptop has an Intel Graphics HD5500, which should also support this.
As I understand, with MST mode I should get two virtual monitors (DP1-1, DP1-2 or something),
instead of that all I'm getting is one DP1 device and I see this - https://www.dropbox.com/s/1toa4v4clxg71jf/2015-04-13%2012.04.04.jpg?dl=0 Dropbox - 2015-04-13 12.04.04.jpg
I tried 3.19, 4.0-rc and 4.0-intel-drm-nightly kernels.
Allan_J_Intel1
You can try any of the Linux support groups to see if there are any drivers available that will provide you with the functions you require.
http://www.linux.com/community Login | Linux.com
See here for more information about Linux* support:
http://www.intel.com/support/graphics/sb/CS-010512.htm http://www.intel.com/support/graphics/sb/CS-010512.htm
Allan.
Allan_J_Intel1
Allan.
