从2017年四月份到现在,HD630驱动都存在这个问题:GPU使用率在某一个操作时提高,导致系统卡顿,甚至在桌面点击右键都卡顿!请尽快解决,非常感谢!现在的最新版本为:23.20.16.4849
Hello 盘古新材,
Thank you for joining the Graphics Community. I am sorry to hear you are having issues with this matter.
I would like to gather more information regarding this behavior, please see below;
- In which operation did the GPU usage increase? Does it only increase with the one in question?
- Provide your computer model.
- Provide the Windows® 10 build version installed.
Amy C.
Amy C.:
你好!感谢你的回复!
- GPU使用率会在桌面空白处点击右键时,突然增加很高;然后又降低
- 我的电脑型号:Alienware 17 R4(2017)
CPU:INTEL 7700HQ
内存:(ADATA 8G DDR4 2400)×2
硬盘:三星 960 Pro 512G/日立 1T SATA
显卡:英伟达 1060 6g/HD 630
3.windows 10 Pro 64bit
盘古新材-张洁(James-Pangoo New Material)
Thank you for that information.
Does the issue persist with the driver provided by your computer manufacturer? Find it here: http://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverId=3XRXM Intel HD Graphics 630 Driver for Intel R Core TM i5-7300HQ /i7-7700HQ /i7-7820HK Driver Details | Dell US, please give it a try.
Amy C.
/thread/120128 盘古新材,
Hope you were able to test the driver mentioned above.
Amy C.
