22712 Discussões
HDMI Output failure on windows 8 with Intel(R) HD Graphics WDDM1.1
Funcionário
21.466 Visualizações
Just upgraded to windows 8 on my laptop and now my HDMI output is no longer working. I was using windows 8 preview and the HDMI output worked just fine. I have tried to update the driver with this download:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000
but when I do I receive an error message that reads:
"This computer does not meet the minimum requirements to install the software."
I have tried using the windows 7 64 bit driver located here:
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21776/a08/Win7Vista_64_152257.exe&lang=eng&Dwnldid=21776&DownloadType=Drivers&OSFullname=Windows+7+(64-bit)* Download Center
but my HDMI output doesn't work with that drivertput
Any help would be greatly appreciated. I miss my 22" monitor.
59 Respostas
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
Hello Navot & PhucNH.
@Navot: Can you try to use your OEM's latest driver for our graphics? You currently have our latest, which may not be supported by your system. Here's a link to that driver; http://support.asus.com/download.aspx?SLanguage=en&p=3&m=UX31E&hashedid=okyFhGJT4AM8jMkZ ASUSTeK Computer Inc. -Support- Drivers and Download UX31E It's listed under "VGA", version .2843. Let's start here and see if there's any improvement.
@PhucNH: I just checked your OEM's support website for your product. It does not currently have Windows 8* support. What this means is that a critical BIOS update or other software update has not been provided by the OEM to make your system compatible with the new OS. The Windows Update* provided in-box driver will make your graphics compatible, but the rest of your system still isn't. Unfortunately, you'll need to either re-install Windows 7*, or contact your OEM for more assistance with this.
-Nic
Funcionário
3.787 Visualizações
Hi Nic,
Well i installed the OEM's latest driver and gave it another shot, but no luck it still won't work...
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
@Navot & PhucNH: What displays are you attempting to connect to?
-Nic
Funcionário
3.787 Visualizações
@Nic: i want to connect to Panasonic TV but it doesn't display
-PhucNH
SDamo1
Principiante
3.787 Visualizações
Hi Nic, I am having a similar problem with my Windows 8 and an HP envy DV6. I am trying to connect via HDMI to my Vizio tv. No audio/no video. Any help would be appreciated. My dxdiag is below:
System Information
Time of this report: 5/26/2013, 15:12:31
Machine name: SLDLAPTOP
Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP ENVY dv6 Notebook PC
BIOS: F.12
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8082MB RAM
Page File: 3747MB used, 5550MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_181B103C&REV_09
Display Memory: 1664 MB
Dedicated Memory: 32 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD034A
Native Mode: 1366 x 768(p) (59.989Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2817 (English)
Driver Version: 9.17.10.2817
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread group
Driver Attributes: Final Retail
Driver Date/Size: 7/27/2012 17:32:00, 8281600 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-3571-1638B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x181B103C
Revision ID: 0x0009
Driver Strong Name: oem5.inf:5f63e5341859ec8c:iIVBM0:9.17.10.2817:pci\ven_8086&dev_0166&subsys_181b103c
Rank Of Driver: 00E00001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) F...
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
Hi Sheri,
Make sure your driver is up to date first. See if either our latest or HP's* latest correct your issue.
Our driver: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22605&lang=eng Download Center
HP* driver: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=5314962&prodTypeId=321957&prodSeriesId=5296055&swLang=13&taskId=135&swEnvOID=4132 HP ENVY dv6-7200 Notebook PC series - Download drivers and software - HP Business Support Center
Is the input source on your TV set to use the HDMI connection? Have you tested both the cable and the TV with a different system? Can you try a different HDMI cable?
-Nic
ACrab
Principiante
3.787 Visualizações
Hi Nic,
I am also having a problem with HDMI output (no video or audio) on my Lenovo S300 notebook with Win8 64 bit and HD3000 graphics. I have tried multiple monitors/TVs and different cables, and updated my graphics and chipset drivers. I have provided my dxdiag infomation in case you can help - thank you!
Andrew
System Information
Time of this report: 7/6/2013, 12:52:41
Machine name: IDEA-PC
System Manufacturer: LENOVO
System Model: 9803
BIOS: 6DCN88WW(V8.02)
Processor: Intel(R) Pentium(R) CPU 997 @ 1.60GHz (2 CPUs), ~1.6GHz
Memory: 4096MB RAM
Available OS Memory: 3958MB RAM
Page File: 1867MB used, 2794MB available
Windows Dir: C:\windows
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0106&SUBSYS_397717AA&REV_09
Monitor Id: LGD034C
Native Mode: 1366 x 768(p) (60.032Hz)
Driver File Version: 9.17.0010.3062 (English)
Driver Version: 9.17.10.3062
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Compute Preemption: DMA
Driver Date/Size: 3/8/2013 19:10:18, 12615680 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4246-11CF-EC7F-7D19B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0106
SubSys ID: 0x397717AA
Revision ID: 0x0009
Driver Strong Name: oem28.inf:5f63e534c4a533dd:iSNBM0:9.17.10.3062:pci\ven_8086&dev_0106
Rank Of Driver: 00E02001
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
Hi salesac1,
Cables seem to be at the root of many of these black-screen issues as of late. Can you verify that your cable works with a different system/display, and if so - check your cable to make sure that it properly fits in the HDMI port on your system?
-Nic
ACrab
Principiante
3.787 Visualizações
Hi Nic,
Thanks for your reply. I have just tried it again with two different cables, each of which is outputting good video & audio from different systems onto different HDTVs/monitors. I removed the cable from each and plugged it directly into my S300. As soon as I do this, both my system and the external monitor go black. I have no option to do anything other than remove the cable. My system display then reverts to normal and the external monitor returns to 'no signal'. So the cable is making a connection, but not providing any actual output. On some occasions I have managed to switch the display back to the laptop, and within the Intel Graphics Manager I have seen that the second screen is identified correctly. The cables do appear to fit properly into the HDMI port on my system.
Thanks again,
Andrew
ACrab
Principiante
3.787 Visualizações
Any further ideas on my issue Nic? Did my dxdiag reveal anything?
Andrew
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
Hi salessca1,
Sorry for the delay in response - I've been working on this issue myself here recently now that we have a system showing a particular black-screen issue. Would you be able to verify for me if connecting two monitors to your system shows a difference in the issue? As in, put one monitor via one cable, and another monitor via another cable at the same time.
Thank you,
-Nic
ACrab
Principiante
3.787 Visualizações
Hi Nic,
Lenovo diagnosed both software and mainboard faults with my laptop. I sent it away and it was returned yesterday. HDMI output now appears to work fine, so I guess we will never know the exact reason for my issue.
Thanks for your assistance anyhow,
Andrew
KFors
Principiante
3.787 Visualizações
Nic - I am another offender that can't get the second monitor to work. My machine is an Envy 14 1210nr. I have tried to reinstall drivers from the HP website to no avail. Any suggestions?
System Information
Time of this report: 9/5/2013, 19:32:52
Machine name: KEITHENVY-HP
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504)
System Model: HP ENVY 14 Notebook PC
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz (4 CPUs), ~2.7GHz
Memory: 4096MB RAM
Available OS Memory: 3894MB RAM
Page File: 3541MB used, 4319MB available
Windows Dir: C:\WINDOWS
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
Card name: Intel(R) HD Graphics (Microsoft Corporation - WDDM 1.1)
Chip type: Intel(R) HD Graphics (Core i5)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_1436103C&REV_02
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Monitor Id: LGD02B6
Native Mode: 1366 x 768(p) (59.636Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igdumd32,igd10umd32
Driver File Version: 8.15.0010.2702 (English)
Driver Version: 8.15.10.2702
DDI Version: 10
Feature Levels: 10.0,9.1
Driver Model: WDDM 1.1
Driver Date/Size: 7/25/2012 23:07:44, 6549504 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-0279-3C34A2C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x1436103C
Revision ID: 0x0002
Driver Strong Name: igdlh11.inf:5f63e5349ded771f:iILKM0:8.15.10.2702:pci\ven_8086&dev_0046
Rank Of Driver: 00E32001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_MOCOMP DXVA2_ModeWMV9_MoComp DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_MoComp DXVA2_ModeVC1_IDCT
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_Al...
NICHOLAS_F_Intel
Funcionário
3.787 Visualizações
Hi keithinphilly,
The display you have that is not showing - have you tried connecting it just by itself to see if it works? If not, consider replacing the cables you are trying to connect with. Make sure it is a straight-through connection as well, no adapters/adapter cables, no KVM's, no AV/R's.
Also, if you are still having the issue after the above steps, provide me with your Intel® Graphics Driver Report and I'll take a look! Steps for getting that report are here; http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics — Intel� Graphics Driver Report
-Nic
KFors
Principiante
3.787 Visualizações
Nic,
The monitor and cable appear fine. Here is the Intel graphics report:
Intel® HD Graphics (Core i5)
Report Date: 9/20/2013
Report Time[hr:mm:ss]: 10:24:2
Driver Version: 8.15.10.2858
Operating System: (6.2.9200)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 3893 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 142 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2660 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2056.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12.60 inches
Vertical: 07.09 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 B6 02 00 00 00 00
00 14 01 03 80 20 12 78 0A 1F 65 9E 5F 58 9C 27
1B 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 78 50 00 0E 30 20 20
24 00 41 B5 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 35 57 48 31 2D 54 4C 42 31 00 62
* Other names and brands are the property of their respective owners. *
Funcionário
3.787 Visualizações
Hi Nic, or anyone else that can help. I am having this issue today sending video out HDMI from my Acer R7-572 running windows 8.1 . It was working fine yesterday so not sure what changed. I have also tested the monitor with the same cable on my other laptop and it detects and works just fine. Every time i connect it back to the Acer R7 I just get no signal on the monitor display.
I've tried both the latest driver off windows update and the older one off the acer support page for that unit. I am currently on the acer supplied driver. I've also updated the bios to latest.
Here is my dxdiag system information;
System Information
Time of this report: 7/14/2014, 15:37:04
Machine name: VISTA
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
System Manufacturer: Acer
System Model: Aspire R7-572
BIOS: V2.04
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz (4 CPUs), ~2.3GHz
Memory: 8192MB RAM
Available OS Memory: 8072MB RAM
Page File: 1431MB used, 7920MB available
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: UnKnown
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 2: No problems found.
Display Devices
Card name: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0A16&SUBSYS_08151025&REV_09
Display Memory: 1792 MB
Shared Memory: 1760 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Id: AUO12ED
Native Mode: 1920 x 1080(p) (60.208Hz)
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3215 (English)
Driver Version: 9.18.10.3215
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Date/Size: 7/14/2014 15:09:28, 8663552 bytes
WHQL Logo'd: n/a
Device Identifier: {D7B78E66-4956-11CF-1A7F-1F28B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0A16
SubSys ID: 0x08151025
Revision ID: 0x0009
Driver Strong Name: oem32.inf:5f63e5341cc65b69:iHSWM_w8:9.18.10.3215:pci\ven_8086&dev_0a16&subsys_08151025
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX Video...
Jose_H_Intel1
Funcionário
3.787 Visualizações
Perhaps a complete uninstall of Intel® HD Graphics driver will help, first from Programs and Features and then from Device Manager. You may also use Windows* System Restore.
Jose_H_Intel1
Funcionário
3.787 Visualizações
I see most of the people in this thread have Intel® HD Graphics (first generation). Let's remember that if you decide to use Windows* 8 only the Microsoft* inbox driver is available through Windows* Updates. Besides a straight-through connection, another option you can try is updating your BIOS.
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics — Supported operating systems
For Intel® HD Graphics 4000 we have a new driver version: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23858 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23858
Responder
