22941 Discussions
HDMI not working with intel driver ACER E-571G
VBiel1
Hello, i'm using win 10 64bit and cant connect to TV with hdmi cable, before i used win 8.1 and sometimes it's working but always need to reinstall driver.
NOW HAVE:
intel graphip driver: 10.18.15.4248
2015-06-29
CPU: intel i5-4210U
attach file dxdiag, how to fix it? i can't update driver, cause always showind unsuported
VBiel1
tried a lot of drivers....
VBiel1
or geting this error
VBiel1
CPU INFO:
Intel(R) Processor Identification Utility
Version: 5.60.20161208
Time Stamp: 2017/05/10 16:33:36
Operating System: 6.2-9200-
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 2
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz
Type: 0
Family: 6
Model: 45
Stepping: 1
Revision: 1D
Maximum CPUID Level: D
L1 Instruction Cache: 2 x 32 KB
L1 Data Cache: 2 x 32 KB
L2 Cache: 2 x 256 KB
L3 Cache: 3 MB
Packaging: µPGA/BGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Intel(R) HD Graphics 4400
Base TDP: 15 W
Expected Processor Frequency: 1.70 GHz
Reported Processor Frequency: 2.39 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
VBiel1
updated driver to :
20.19.15.4531
2016-09-29 but nothing changed
Stefan3D
So you have the predecessor to my laptop (E5-571G).
Regarding second monitor over HDMI:
Right-click on desktop
select display settings
then select extend displays
Also i have to select the input on my monitor's OSD menu manually.
Regarding generic drivers:
They work fine with Acer, but you have to install them via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
VBiel1
VBiel1
driver updated with disk method, but hdmi not working 😕
Stefan3D
There seems to be no physical connection?
Try another cable or another monitor.
The display options should appear below orientation. I add a screenshot for reference.
VBiel1
i cant find this setting, i will try tomorrow with other cable
VBiel1
i'm tried connect computer with monitor, and this not working. no problem with cable
Stefan3D
Test monitor with other device (DVD player, XBOX whatever).
Try the VGA connection of your laptop.
Check device manager for yellow bangs.
Your BIOS is up-to-date, i have the same. Nothing you can do there.
I'm running out of clues...
Hello Vilmantas,
Thank you for contacting the Intel community.
I'm sorry that you haven't been able to connect the external monitor.
Are you using any adapter or you are using straight connection? If so, try straight connection instead.
You can also right click on the desktop and select the Intel® Graphics properties and then click display, you will see the multiple display option, and there you can see if the external display is connected. If nothing is there, as Stefan3D mentioned above there is no physical connection to the monitor, so this could be an issue either with the monitor, the HDMI cable or the HDMI port is defective.
You can try contacting your computer manufacturer; they could have specific configuration or BIOS update that can help. Here is where you can get support:
https://www.acer.com/ac/en/US/content/drivers https://www.acer.com/ac/en/US/content/drivers
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
