- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi, I'm having picture quality problems with my DG45FC board and the X4500HD IGP. I plug in a DVI cable and the picture is perfect. The monitor I'm using - an NEC LCD - is detected in the Graphics and Media Control Panel as a "Monitor..." The problem is when I plug in via an HDMI cable the same monitor is detected as a "Digital Television..." and I think this is the cause for my poor quality picture. I'm getting a blurred effect with red and green fringeing around text. It's really annoying. I've read about similar issues with nVidia cards and HDMI and a registry hack as a workaround to fix. Does anyone know a way to fix this with the Intel IGP? Thanks.
- 태그:
- HDMI
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I'm having the same issue. I have 2 monitors, one connected through DVI, the other HDMI. The DVI looks perfect and shows as "Digital Display", but the HDMI is all washed out and shows as "Digital Television". How do you change this?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I never got it working properly. I ended up buying a DVDO iScan Duo and that did correct any issues I had with the Intel video (but at a cost obviously). It's also a useful device because it corrects other issues with computer to TV signals like overscan without having to fiddle with the PC video settings.
