23817 Discussions
HELP PLS
efedergoat
hello guys i wanted to try the intel controlmenu wit hthe colours but now my colours look wierd anf if i try to reset them or fix them it doesnt work i also tryed restarting my pc didnt work pls help i want normal colours not these goofy looking colours
Carlos_L_Intel
Hi @efedergoat,
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
  • Are you referring to the Intel® Graphics Command Center?
  • Can you show us a screenshot or a video of the issue?
  •  To get more information from your system, please install the Intel® System Support Utility (Intel® SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
Carlos L.
Carlos_L_Intel
Hi @efedergoat,
Were you able to check the previous post? Let us know if you still need assistance.
Carlos L.
Carlos_L_Intel
Hi @efedergoat,
Carlos L.
