23086 Discussions
HELP The older version of intel computing improvement cannot be removed If I want to update intel driver I get to see this error. Intel computing inprovement removed with geek, had to do forcing. But I still can't download Intel Assistant
jnora1
AlHill
Use this uninstaller: https://downloadcenter.intel.com/download/28598/Intel-Driver-Support-Assistant-Uninstaller?v=t
Then, install the latest IDSA. During the installation, DECLINE the install of the CIP. It will install anyway.
Do not choose to LAUNCH IDSA after the install. Instead, go to the control panel, programs and features, and uninstall the CIP.
All of this assumes you are on Windows 10 version 1809. If not, you should be.
Doc
jnora1
Good evening
Thank you for the solution
But I just restored my laptop to how it was originally from the factory, without losing any software. That worked super well!
Only a few hours lost, no drama
Julia
AlHill
Glad you have it solved.
Doc
