23281 Discussions
HP Probook 4510s persistant graphics challenge
MNotn
I own a Probook 4510s Notebook - NA915EA, it's warranty is already expired.
The problem lies with the Mobile Intel(R) 4 Series Express Chipset Family [PCI\VEN_8086&DEV_2A42].
Whenever I do not install any driver for this part it works fine. The display resolution can be set to 1024x768, but I cannot connect a hdmi screen to it.
When I do install a graphics driver the following happens:
> I enable driver installation (gpedit.msc\Local Computer Policy\ Computer Config \ Administrative Settings \ System \ Device Installation \ Device Installation Restrictions \ Precent installation of devices not described by other policy settings -> Not Configured)
> I install the driver, WinSAT & Aero enabled.
> I disable driver installation to prevent windows from messing up
> I restart the Probook
> The Probook loads all drivers fine
> The welcome screen appears with black pixels all over the screen
> The welcome screen refreshes 3 times; every time the pixels are on a different place
> Blue Screen of Death
Technical information:
STOP: 0x0116 (0xFFFFFA80072C0010, 0xFFFFF88002A4CB0, 0x0..0, 0x0..000D)
igdkmd64.sys - Address FFFFF88002A4CB0 base at 0xFFFFFA80072C0010, DateStamp 4a01d55b
> I enable driver installation (gpedit.msc\Local Computer Policy\ Computer Config \ Administrative Settings \ System \ Device Installation \ Device Installation Restrictions \ Precent installation of devices not described by other policy settings -> Not Configured) (same as above)
> I install the driver, WinSAT & Aero disabled.
> I disable driver installation to prevent windows from messing up (same as above)
> I restart the Probook (same as above)
> The Probook loads all drivers fine (same as above)
> The welcome screen appears with black pixels all over the screen (same as above)
> The welcome screen refreshes 3 times; every time the pixels are on a different place (same as above)
> Screen turns black and desktop appears
> Spam pop-up:
- Display driver stopped responding and has recovered,
- Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has sucessfully recovered.
> The Probook freezes and I am forced to shut it down
I run Windows 7 - 64 bit with Service Pack 1
I hope there's someone out there with the solution
DArce
Valued Contributor III
The error message you get in the second scenario is similar to what has been described and troubleshoot on this thread:
/thread/32928?start=375&tstart=0 http://communities.intel.com/thread/32928?start=375&tstart=0
Try using the latest driver that has been provided by Hewlett Packard* for your system and install the latest BIOS for your computer. This is available here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3934828&taskId=135 HP ProBook 4510s Notebook PC | Download drivers and software - specify product name - HP Business Support Center
