23526 Discussions
HP x2401 (+ HDMI-cable) does not work in Windows 10 with Intel(R) HD Graphic 4600
RPauw
HP x2401 (+ HDMI-cable) displays in Windows 7 with NVIDIA GeForce GTS 250, but
HP x2401 (+ HDMI-cable) does not work in Windows 10 with Intel(R) HD Graphic 4600.
prik
IUman
Hello prik,
Thank you for joining the Intel communities.
What is the issue you get, no display, bad image etc?
Did you try installing the latest https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Intel graphics driver?
Have you tried different HDMI cable?
Are you using any adapters or straight connection from the unit to the monitor?
Please reply with the graphics report:
Go to Intel® Graphics and Control Panel > Options > information Center > Save.
Best wishes,
Ivan
RPauw
Hallo Ivan,
- er was geen beeld, no display,
- installed the last 'intel graphic driver': no result,
- I have adapters and had tried 'straight': no result with a 'round' cable, but
- tried 'straight' with a 'flat' HMDI-cable and it worked!
So, dear Ivan, a combination of your proposals: 'that's the sollution'!!
BIG thanks for your help!
prik
IUman
I'm glad that the information I provided was able to solve your problem and thank you for letting me know.
