22924 Discussions
Not recognising new TV connected via HDMI
PMora4
Hardware:
Intel Skylake i3 6100
ASRock B150M mainboard.
Samsung 55JS7200 TV.
Software:
Ubuntu Server 15.10, Kernel 4.4.1.
Description:
Trying to connect my HTPC box to a new television. If I disconnect HDMI from existing TV and plug it into the new TV then I get a picture. If I restart Ubuntu/Xorg server/Kodi after doing so, then it's no signal. Likewise, xrandr says it can't open the display.
If I reboot, I don't even see the BIOS screen on the new TV. If I connect back to my old LG TV, then unplug, I can see the screen again.
I've tried connecting using three different HDMI cables and every port on the new TV with the same result. I also tried a DVI to HDMI adaptor and got the same result.
I've tried connecting other devices, laptops to the same HDMI ports on the TV and they all work fine.
As I can't see the BIOS screen on the new TV I am thinking this is something quite low level, probably. If anyone has any ideas then I would be very appreciative!
Anonymous
Not applicable
Hi grantonstar,
Try with this open source graphics driver.
https://01.org/linuxgraphics Intel® Graphics for Linux* | 01.org
Mike C
PMora4
Hi Mike,
I replied in the bugzilla I raised for this. Can the drivers be installed via the command line? I'm running a limited Xorg (for Kodi) not a full desktop environment. Also, how do these differ from those in the kernel?
Thanks for replying,
Anonymous
Not applicable
Hi grantonstar,
Intel has a team specialized on open source operating systems; I suggest you to post your question on their forum.
https://01.org/linuxgraphics/forum/ https://01.org/linuxgraphics/forum/
INTEL® GRAPHICS INSTALLER 1.4.0 FOR LINUX*
https://01.org/linuxgraphics/downloads/intel-graphics-installer-linux-1.4.0 Intel Graphics Installer for Linux* 1.4.0 | 01.org
Mike C
