23769 Discussions
HTPC keeps losing its Intel display driver
cshon
I have the following system which I use as a HTPC running XBMC
HTPC system:
Intel Core i5-4670T(2.30GHz) HD4600 graphics
ASRock Z87E-ITX motherboard
8Gb RAM
250Gb SSD
Windows 8.1
I have the Intel display graphics driver installed (latest version) and HDMI is set as the default output. This works fine when the HTPC system is connected to the AV amp. However, if I ever turn on the HTPC without an active HDMI connection to the amp or access it via Remote Desktop, the display driver gets lost. It stays 'uninstalled' even when the full system is reconnected (and XBMC fails to load). Reinstalling the graphic diver appears to be the only cure
I would like to manage the system by Remote Desktop occasionally, so is there any way I can stop this happening?
Thanks for any input.
