23854 Discussions
Haswell-ULT Integrated Graphics Controller vs 3rd Gen Core processor Graphics Controller
NK2
Good afternoon!
I have Lenovo IdeaPad G500A (59-381065) notebook with Intel HD Graphics 4000 and AMD Radeon HD 8750M videocards inside. I use Linux openSUSE 13.1 (tried also other distributions with the same result).
The problem is that graphics doesn't start on AMD card with fglrx driver:
<6>[fglrx] Try to set gart size 2697M failed, should be within 0M and 0M. Discard the setting.
in dmesg and
[ 26.319] (EE) fglrx(0): Failed to open CMMQS connection.
in /var/log/Xorg.0.conf.
In the same time it does run on the very similar notebook Acer Aspire E1-572G (this is described in https://forums.opensuse.org/showthread.php/496315-AMD-Intel-drivers-problem AMD / Intel drivers problem) without any problems. Olav from that discussion and I have the same AMD cards. Our Intel cards are different:
Olav's
# lspci -nnk | grep 'VGA'
00:02.0 VGA compatible controller [0300]: Intel Corporation Haswell-ULT Integrated Graphics Controller [8086:0a16] (rev 09)
vs my
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
This is the most obvious difference of our machines in relation to my problem (I don't think that the manufacturer of notebook as whole does matter...).
Could anybody explain what is the difference between these two integrated cards in the relation to the problem?
If anybody has the similar notebook (with working Intel/AMD PowerXpress with fglrx), please, provide the result of
# lspci -vvvxxxnn -s 00:00:02.0 && lspci -vvvxxxnn -s 00:01:00.0
where 00:00:02.0 and 00:01:00.0 are the BusIDs of the videocards (taken from the result of lspci command).
Any help is appreciated.
Regards, Natalia
Not applicable
I noted you have Linux operating system and you are using switchable graphics on your laptop. This configuration requires a special graphics driver provided with the laptop manufacturer.
Intel provides with graphics drivers compatible with Microsoft® Windows operating systems; however, Intel has an Open Source project. From their website you will find graphics drivers for Linux. I recommend you to be part of their community.
https://01.org/linuxgraphics Intel Graphics for Linux* | 01.org
NK2
Thank you for reply.
Yes, I know that drivers from the site of notebook manufacturer would be the best variant in my case. But drivers for Linux are absent at lenovo.com, at least, for my laptop... Intel card by itself works properly with driver from https://01.org/linuxgraphics Intel Graphics for Linux* | 01.org .
The question is why AMD card does work with Haswell-ULT Integrated Graphics Controller while it doesn't work with 3rd Gen Core processor Graphics Controller?
As I understand, AMD card outputs data to the Intel card, and Intel card delivers it to the screen in PowerXpress systems. But which characteristics of Intel card can allow AMD card interact with one integrated card and forbid this for another?
Knowing this, I think, possibly might help to change code of kernel/driver in order to obtain working graphics...
NK2
Thank you for this link. May be, it is worth to write also there...
