22656 Discussions
Having a problem in resetting my Graphics driver on my HP ProBook 450 G3 Laptop running: Windows 10
ChrisCanfield
Driver seems to not want to properly & cleanly un-install & could use some help as to how to fix this.
UN-INSTALL PROCESS BEING DONE:
1. Uninstall: "Intel Driver & Support Assistant"
2. open "Device Manager" & under: "Display adapters",
right click over: "Intel(R) HD Graphics 520" & select: "uninstall"
[manually checking box for: "Delete the driver software for this device."]
3. a. Restart the laptop.
3. b. Verify that driver has been properly uninstalled by opening:
"Device Manager" & under: "Display adapters", & it should read:
"Microsoft Basic Display Adapter"
4. Re-install: "Intel Driver & Support Assistant",
Load: "Intel Driver & Support Assistant", & see if any updates are available by program being forced open in the default web browser.
ON MY END, via my browser, after loading: "Intel Driver & Support Assistant",
THIS IS WHAT I SEE:
TAKE NOTE OF THE DATE
I think it should reflect when u have installed the driver / if u re-install it, it should reflect with the updated date.
THE DATE SHOWING UP: Intel Graphics Display (date of install).png
TODAY's date:                         7/15/2024
LAPTOP DATA:
HP ProBook 450 G3
Product #: W0R57UT#ABA / SERIAL #: 5CD748BSQG
OS:        Windows 10 Pro. - 64 bit
WINDOWS UPDATE VERSION:                  22H2
OS Build #:                                                      19045.4651
Windows Feature Experience Pack #:     1000.19060.1000.0
(OS data recorded on: 7/10/2024 - Wed. @ 1:24AM / EDT)
Please provide some help 4 me with this issue
Senkuchan
Valued Contributor II
Whats the model of your processor? I want to check if the driver assistant is providing the correct driver. Also, have you tried using ddu? Here’s the link: https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
