23727 Discussions
Hd graphic installation
MTeel1
Hi everyone. I have just install windows update utility and before i do try anything i just want to confirm how to update intel iris and hd graphics driver for windows 8.1 64bit ver 10.18.10.3643 using the update utility. Also do i have to uninstall the old driver and install the new one or does windows update utility does it all? Hope my question make any sense. Thanks again for all the support.
Kevin_M_Intel
Hello mokracken,
Your question is completely correct and valid so let me help you with this.
The driver version 10.18.10.3643 is an old version at this point so you can get a newer driver for your graphics controller.
The best way to install a graphics driver is uninstalling the current and installing the new one so I just would like to what is the graphics controller your system has?
Here you can refer to know
http://www.intel.com/support/graphics/sb/CS-009482.htm http://www.intel.com/support/graphics/sb/CS-009482.htm
Kevin M
MTeel1
Hi Kevin
Thanks for the reply, my graphics controller is Intel(R) Hd graphics 4600. Would really appreciate if you could guide me through the installation and updating steps. Kind of new to all of this. Thanks again for everything
Mokracken
Kevin_M_Intel
Sure!
Please download and install the latest driver from here:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348
You can also refer to installation instructions here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Let me know how it goes!
Kevin M
