23486 Discussions
Hdmi audio
nmanc1
my pc thinkcentre model m83 10e9-0002 lX connected to the multimedia monitor via cable displayport hdmi, not sending audio.
the settings on windows seven are ok, the tv is set as the default audio device, and even on monitor is all right, all drivers and bios lenovo updated but you do not hear the audio
you have other solutions?
thank you
Allan_J_Intel1
It might be that you need the latest video drivers for your graphics controller since the driver contains HDMI codec drivers. Production drives linked below:
https://downloadcenter.intel.com/download/25425/Intel-Graphics-Driver-for-Windows-7-8-1-15-36- Download Intel® Graphics Driver for Windows 7/8.1* [15.36]
Additionally, please make sure to test different cables, if possible use straight cables, in others words, same end on both sides of the cable.
Allan.
nmanc1
Hi Allan, thanks for the reply but I already installed the recommended driver and I also tried to connect a cable display port / display port without results
I feel incredible, some other solution?
thank you
Allan_J_Intel1
See this URL it mentions to try to update BIOS on post# 73
Additionally, I recommend contacting http://www.shoplenovo.ch/info/contact_us Lenovo Online Catalogue : Information > Contact Us for more information about this matter.
Allan.
