23854 Discussions
Hello I have a problem while encoding using quick sync, my graphic card usage keeps spike every 5 sec from 20% to 100%. It makes my computer stutter. Please kindly advise. Thank you.
SOneT
PC specification X556UQK, 4GB RAM with MX 940 Nvdia graphics
AlHill
Are you saying you do not have intel graphics, just nvidia graphics? If so, you need to be contacting nvidia. It looks like from the specifications at ASUS that you only have nvidia graphics.
Only 4GB RAM? If you are running Windows 10, 1909, that is awful low memory.
Doc
SOneT
intel graphics 620 with nvdia mx 940. I'm seeing like some kind of bug tht spikes up my gpu usage for 0.5 sec every 4-5 sec
AlHill
Are you using both the intel and nvidia driver from ASUS?
Confirm that you are running Windows 10 1909.
Doc
SOneT
yea i use mx 940 for my graphics and trying to decode with QSV
AdrianM_Intel
Hello SOneT,
Thank you for posting on the Intel® communities.
Do you still need assistance? if so please generate the following reports:
1. Intel® System Support Utility (Intel® SSU)
Intel® SSU Download link
Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Click on the menu where it says "Summary" to change to "Detailed View".
To save your scan, click on "Next", then "Save".
2. DXDIAG
Go to Start > Run or Windows Key + R.
On the Run prompt, type "dxdiag" then click OK.
On the DirectX Diagnostic Tool window, click on Save All Information.
Browse to a folder, type in a filename then click Save.
Please share screenshots of the GPU usage.
Adrian M.
AdrianM_Intel
Hello SOneT,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
