20766 Discussions
Help Me Run Just Cause 3 on Integrated Graphics - Intel HD Graphics 4000
JFace
Currently, I have just purchased Just Cause 3. With DLC included, and only have Intel HD Graphics 4000. And plenty of space on my hard drive.
The Problem Is... it lags, and stutters.
I get low FPS... very low FPS. I also wait for the game to load then connect a controller. Are there any mod(-ification)s that I can use, or a way to make it run faster?
Thanks and have fun.
Thank You.
Hello ROBOKILLER1337,
Thank you for contacting the Intel community.
Do you have the latest graphics driver installed? If not, you can download it here:
https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499 https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499
if you get an error installing this driver, uninstall the older version and install the newest version manually, please see https://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver and see how to https://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
Ivan U.
JFace
Well, here is the deal. I'm running on Windows 10 on what used to be a 32-bit Windows 8.1
Thank you for the information ROBOKILLER1337, in this case, I was reviewing the system requirements for Just Cause 3 and it requires a 64 bit operating system you can check here:
http://gamesystemrequirements.com/game/just-cause-3 http://gamesystemrequirements.com/game/just-cause-3
Most likely the issue you get is because you are using 32 bit operating system, I'm pretty sure with 64 bit your game will run much better.
Ivan U.
