22747 Discussions
Help me how to change dedicated video card!
I'm using Intel Graphic HD, After intall driver, I see my card has: Minimum Graphic Memory: 32MB, Maximum Graphic Memory: 1247GB but Graphic Memory In use only 52MB. Could you tell me how I can change my dedicated graphic memory. Some computer I can fchange this on BIOS, but in this my computer I cannot find it anywhere. Could you tell me how I can change this graphic memory in use. Thanks so much!
Edward_Z_Intel
Graphic memory is dynamically allocated. It will increase when more graphics memory is required. You don't need to do anything to change it.
I know it is adjusted automatically, but there are some program requires more minimum graphic memory, how can I config this? for example: PES10 hihi. Could you help me config this card to play PES10, tks co much!
I have problems with the video card 964GM. It does not support OpenGL 2.0? I would like to use the options OpenGL / GNU software Photoshop CS5, but the program says that the video card does not support. My driver is updated.
Any solution?
If not, I can replace my video card?
Thank you.
Eu tenho problemas com a placa de vídeo 964GM. Ela não suporta OpenGL 2.0? Eu gostaria de usar as opções OpenGL/GNU do software Photoshop CS5 mas o programa diz que a placa de vídeo não dá suporte. Meu driver está atualizado.
Alguma solução?
Se não, eu consigo substituir minha placa de vídeo?
Obrigado.
