22787 Discussions
How can I change my display resolution by add custome resoulation
Hpprobook
I have a question about how can I change the resoulation for HP probook i5
I have a normal resoulation display for uhd grafic 620 so I would like to add resoulation by add graphics command center but I can't add a resoultion becasue my custom resoulation is not suppored on internal display so How can I change the display to add better resoulation than 1366 *768 .
n_scott_pearson
You can't. If you want a better resolution internal display, you need to purchase a laptop that has an internal display that supports that better resolution.
Sorry, reality bites,
Jean_Intel
Hello Hpprobook,
You should know that custom resolutions are not supported for internal displays in the Intel® Graphics Command Center. Previous versions of the Intel Graphics Command Center showed the Custom Resolution setting for internal displays but did not actually allow a custom resolution to be applied, therefore the Custom Resolution setting was removed. This is considered to be expected behavior.
Jean O.
Jean_Intel
Hello Hpprobook,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
