23012 Discussions
How can I monitor ARC GPU's VRAM usage in Linux Mint
NineMeow
I initialized two GPUs on my computer, one is UHD 630 and the other is ARC A770(Resizable BAR ON).
I have tried ATOP, HTOP, intel_gpu_top, etc. They didn't show me the VRAM usage of my A770.
Jean_Intel
Hello NineMeow,
Thank you for posting in the Intel Communities. We see that you are having issues finding a way to monitor ARC GPU's VRAM usage in Linux Mint. We will help you on this matter, but we will further review this information internally, and we will post back as soon as we have more details. Please allow us some time to check this.
Jean O.
Jean_Intel
Hello NineMeow,
We appreciate your patience. Unfortunately, currently, there is no Intel tool to monitor VRAM in Linux. However, we have passed your feedback to the Arc Control Developer team to have a similar solution in this Operating System, though we can't promise any estimated time or a particular outcome.
Let us know if you have any other questions.
Jean O.
DeanL
Hi There!!! Are you using Conky?   I've been experimenting with exposing GPU values to Conky....In talking with another Arc user....he has tried this:
Sure, I can help you with that. Here are the command-line commands you can use to monitor the temperature, memory, and GPU speeds of your Intel Arc-based video card:
To get the temperature of your video card, you can use the following command:
cat /sys/class/drm/card0/thermal_zone0/temp
To get the memory usage of your video card, you can use the following command:
cat /sys/class/drm/card0/memory/used
To get the GPU clock speed of your video card, you can use the following command:
cat /sys/class/drm/card0/device/clock_mhz
You can then input this information into your Conky script to monitor your video card in real time.
Here is an example of how you can use this information in your Conky script:
${color yellow}Intel Arc-based video card:
${color}
GPU temperature: ${exec cat /sys/class/drm/card0/thermal_zone0/temp}°C
GPU memory usage: ${exec cat /sys/class/drm/card0/memory/used} MB
GPU clock speed: ${exec cat /sys/class/drm/card0/device/clock_mhz} MHz
This will display the temperature, memory usage, and GPU clock speed of your Intel Arc-based video card in your Conky window.
I hope this helps!
In my case, this resulted in no output, so I started looking in the /sys/class/drm  and in my case, I got some output with:
${color3}Temp:${color0} ${exec cat /sys/class/drm/card0/gt/gt0/throttle_reason_thermal} °C${goto 145}${color3}Mem: ${color0}${goto 185}${exec cat /sys/class/drm/card0/gt/gt0/media_freq_factor} MB
${color3}Freq:${color0} ${exec cat /sys/class/drm/card0/gt_act_freq_mhz} Mhz
So, I'm not getting temp readings, but a variable value from:  {exec cat /sys/class/drm/card0/device/clock_mhz}
That's the best I can offer right now....I play with getting readings now & again. I would be VERY interesting if any of the Intel devs would like to step in here & enlighten us a bit more.......Hint..Hint  😉
NineMeow
Thanks! I will give it a try.
DeanL
Sorry....wrong copy/paste....I'm getting what looks like the right values for MB clock Freq:    ${exec cat /sys/class/drm/card0/gt_act_freq_mhz} Mhz
DeanL
Again--Frequency....not MB
Jean_Intel
Hello Everyone,
We see that fellow community members have jumped in the thread. As mentioned before, there is no Intel software to monitor VRAM in Linux-based Operating System. Nevertheless, you can try the recommended commands and scripts from @DeanL, but it would be recommended that you contact Linux Mint support or the Conky developers for additional information and support for their software.
We have shared the feedback with the appropriate team; however, we can't promise any ETA or outcome.
Jean O.
Jean_Intel
Hello Everyone,
Since we haven't received a response in a while, we will proceed to close the thread. If you require additional information, please open a new question as this thread will no longer be monitored.
Jean O.
NineMeow
I have used xpu-smi for a while. It seems that the program can't support ARC client GPU well so it only shows power(watt) and VRAM usage. But this is quite enough for me now.
Thank you, everyone!
Xanph
Thank you NineMeow, very useful.
Intel really should have their own resource monitoring tool because of their ARC line. I'm now using intel-gpu-top which isn't even made by intel and was last updated 9 years ago, and now have to use xpu on top!
For anyone wanting direct copy and paste instructions for xpu-smi (tested in Ubuntu), here they are:
Step 1: Ensure you have your GPU drivers installed - Client or Data Centre.
Client install: As you have installed the client GPU drivers you will need to run:
Data Centre: You will already have xpu-smi installed
sudo apt install xpu-smi
Step 2: Run discovery on your cards to get the device ID for the specific card you want stats on.
xpu-smi discovery
Step 3: Get the stats for your card, replacing 0 with your device id.
xpu-smi stats -d 0
