23832 Discussions
Iris Xe graphics
Samurai84
Assalam-o-Alaikum (Peace be upon you);
I have a question, is it possible to correctly enable Iris Xe graphics on mixed channel memory (8gb+4gb)? Or strict dual channel is required (8gb+8gb)?
Jean_Intel
Hello Samurai84,
Thank you for posting in the Intel Communities. We would be more than glad to help you.
Based on your question, we want to let you know that to properly enable Iris® Xe Graphics, the system must be in dual-channel memory configuration. You should consult with your computer manufacturer for more information.
Jean O.
n_scott_pearson
Let's be careful with what we are saying here.
If you do not have a dual-channel memory configuration, it doesn't mean that the GFX engine will not work. It just means that it will run in the lesser Intel UHD Graphics mode.
Just saying,
Jean_Intel
Hello Samurai84,
Since we have not heard back from you, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
