22881 Discussions
How can I run 4 monitors on a HD 4600 gpu
PH1
Hi all,
I have the MSI H97 motherboard with four outputs, VGA, DVI, HDMI and Display Port. I can get all four monitors detected in windows in the control panel and the screen resolution menu where they appear side by side. I want to be able to extend my screen to all four, but any time i select the fourth greyed out monitor to connect it, it disconnects one of the others. Is there any way or workaround to force all four monitors to work? Is this a hardware limitation of the gpu not being able to handle more than 3 outputs or should I try to seek support with the motherboard manufacturer?
Cheers!
VTran8
Intel HD Graphics 4600 only supports 3 output, not 4.
