23630 Discussions
How do I fix Intel HD Driver issue with Windows 10 version 1511?
TGeha
Hi Intel Community,
I have had windows 10 on my laptop for a while now and it has been working great for me. I had recently downloaded and updated to version 1511.
After the update finished, my computer restarted and the screen stayed black. I waited for a long time and the screen was not showing anything. I noticed the fingerprint reader LED was blinking meaning i can use it to log in. I logged in and was able to hear some sounds. Surprisingly, my first thought was to disable the Intel driver. To do this, I used Teamviewer on a different computer to log in and see things on a different screen. After that, I was able to see everything on the screen.
I believe there is some kind of issue with the version 1511 of Windows 10 and the Intel display driver.
I have tried downloading the latest driver from Intel's website and that still didn't work.
If it helps, here are some of my specs:
HP Laptop
Intel core i7 3632QM processor with Intel HD 4000
8 GB RAM
nVidia gt 635m GPU
Also, my nvidia gpu isn't working anymore because I believe it is controlled by the Intel driver.
Is there any fix or workaround for this issue? Thanks
Amy_C_Intel
Hello timgehant,
We have received reports about this Windows® 10 version causing issues on several systems, refer to this forum . At this point you could try to using the Last Known Good Configuration, check this link http://windows.microsoft.com/en-us/windows/using-last-known-good-configuration# 1TC=windows-7 Using Last Known Good Configuration - Windows Help.
Amy.
