23263 Discussions
How do I revert to previous display drivers if they can't be found? The UI in Houdini is totally messed up ever since I updated my display drivers and I am currently unable to work.
MBeli8
I have tried using Houdini 17, 17.5 and 18 and they all load up with the same UI issue. The software is currently unusable due to display issues.
I have found only one other post detailing this issue and it seems like the user didn't get any help.
That being said,I would really like to revert back to a prior versior of the display drivers but I am unable to find something that seems legit and safe.
Can anyone help out with this issue?
The current driver I have is : 26.20.100.7262
Product : Intel(R) HD Graphics 615
Thanks!
AlHill
What is the model number of your processor?
Doc
MBeli8
AlHill
You can find all of the windows drivers here:
https://downloadcenter.intel.com/download/29335?product=95441
Note that 7262 is not in this list.
Other information/downloads can be found here:
https://ark.intel.com/content/www/us/en/ark/products/95441/intel-core-i7-7y75-processor-4m-cache-up-to-3-60-ghz.html
Doc
MBeli8
Thanks Doc. I was able to get a prior version of the driver and install it manually. Cheers, Max
n_scott_pearson
I would point out that the latest version of the driver is 26.20.100.7755, which is many, many builds and many, many bug fixes newer. Al provided you with a link for downloading it above.
Max44
You can restore the previous driver by using the rollback option.
  1. Open Device Manager, click Start > Control Panel > Device Manager.
  2. Expand Display Adapters.
  3. Double-click on your Intel® display device.
  4. Select the Driver tab.
  5. Click Roll Back Driver to restore.
I hope this helps!
Max
