23832 Discussions
How do I update my Graphics Driver?
AW
My graphics driver needs updating, as after my update to Windows 10 when I try playing a game it crashes and says that the graphics driver is the issue. I downloaded the Intel Driver Update Utility (2.4) and after the scan it said that 'Intel Chipset Device Software (INF Update Utility-EXE Only)' needs updating to 10.1.1.14. The download goes fine, but when I install it the progress bar goes by quickly and suddenly 'Unknown error' and status says failed. Log shown below. I read a few forums in which people had around the same issue and were never really fixed, I've tried a few suggestions, however, like manually installing the chipset from the website though I couldn't find one with exactly the same name. I did try to install 'Intel Chipset Device Software (INF Update Utility)' which took me through practically the exact same thing as the one from the automatic updater; everything went smoothly until it said it failed because of an unknown error.
I'd really appreciate some help with this as it has been annoying me for a while and I still haven't found a solution.
-Alice
[25D4:2060][2016-04-17T16:08:49]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: C:\Users\Alice\Downloads\Intel Components\SetupChipset.exe, cmdline: '-burn.unelevated BurnPipe.{7B347909-176F-49B8-ACE9-783E8381FC9E} {11ED07EA-4BB0-4885-AA14-7DE40F7DBAD4} 10380'
[25D4:2060][2016-04-17T16:08:49]i000: Initializing string variable 'IIF_ProductVersion' to value '10.1.1.14'
[25D4:2060][2016-04-17T16:08:49]i000: Initializing string variable 'IIF_InstallerVersion' to value '3.1.6'
[25D4:2060][2016-04-17T16:08:49]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx86.msi' to value ';NullDrivers.cab;NOT VersionNT64'
[25D4:2060][2016-04-17T16:08:49]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx64.msi' to value ';NullDrivers.cab;VersionNT64'
[25D4:2060][2016-04-17T16:08:50]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Richard\AppData\Local\Temp\Intel\Logs\Chipset_20160417160850.log'
[25D4:2060][2016-04-17T16:08:50]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Richard\Downloads\Intel Components\SetupChipset.exe'
[25D4:2060][2016-04-17T16:08:51]i052: Condition 'VersionNT >= v6.1 OR (VersionNT = v6.0 AND NTProductType = 3)' evaluates to true.
[25D4:2060][2016-04-17T16:08:51]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[25D4:2060][2016-04-17T16:08:51]i000: Loading managed bootstrapper application.
[25D4:2060][2016-04-17T16:08:51]i000: Creating BA thread to run asynchronously.
[25D4:0988][2016-04-17T16:08:51]i000: ** MBA ** Command line:
[25D4:0988][2016-04-17T16:08:51]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[25D4:0988][2016-04-17T16:08:51]i000: ** MBA ** Calling Engine.Detect()
[25D4:2060][2016-04-17T16:08:51]i100: Detect begin, 3 packages
[25D4:2060][2016-04-17T16:08:51]i000: Setting string variable 'DotNet35' to value '1'
[25D4:2060][2016-04-17T16:08:51]i000: Setting string variable 'DotNet40Client' to value '1'
[25D4:2060][2016-04-17T16:08:51]i000: Setting string variable 'DotNet40Full' to value '1'
[25D4:2060][2016-04-17T16:08:51]i000: Setting string variable 'DotNet45' to value '394254'
[25D4:2060][2016-04-17T16:08:51]i052: Condition 'DotNet35 OR DotNet40Client OR DotNet40Full OR (DotNet45 >= 378389)' evaluates to true.
[25D4:2060][2016-04-17T16:08:51]i101: Detected package: DotNet45, state: Present, cached: None
[25D4:2060][2016-04-17T16:08:51]i101: Detected package: SetupChipsetx86.msi, state: Absent, cached: None
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx86.msi, feature: NullDriverFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx86.msi, feature: PackageVersionFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx86.msi, feature: LicenseAgreementFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i101: Detected package: SetupChipsetx64.msi, state: Absent, cached: None
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx64.msi, feature: NullDriverFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx64.msi, feature: PackageVersionFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i104: Detected package: SetupChipsetx64.msi, feature: LicenseAgreementFeature, state: Absent
[25D4:2060][2016-04-17T16:08:51]i199: Detect complete, result: 0x0
[25D4:2060][2016-04-17T16:09:00]i200: Plan begin, 3 packages, action: Install
[25D4:2060][2016-04-17T16:09:00]w321: Skipping dependency registration on package with no dependency providers: DotNet45
[25D4:2060][2016-04-17T16:09:00]i052: Condition 'NOT VersionNT64' evaluates to false.
[25D4:2060][2016-04-17T16:09:00]i204: Plan 3 msi features for package: SetupChipsetx86.msi
[25D4:2060][2016-04-17T16:09:00]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[25D4:2060][2016-04-17T16:09:00]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[25D4:2060][2016-04-17T16:09:00]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[25D4:2060][2016-04-17T16:09:00]i052: Condition 'VersionNT64' evaluates to true.
[25D4:2060][2016-04-17T16:09:00]i204: Plan 3 msi features for package: SetupChipsetx64.msi
[25D4:2060][2016-04-17T16:09:00]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx64.msi' to value 'C:\Users\Richard\AppData\Local\Temp\Intel\Logs\Chipset_20160417160850_0_SetupChipsetx64.msi_rollback.log'
[25D4:2060][2016-04-17T16:09:00]i000: Setting string variable 'WixBundleLog_SetupChipsetx64.msi' to value 'C:\Users\Richard\AppData\Local\Temp\Intel\Logs\Chipset_20160417160850_0_SetupChipsetx64.msi.log'
[25D4:2060][2016-04-17T16:09:00]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[25D4:2060][2016-04-17T16:09:00]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[25D4:2060][2016-04-17T16:09:00]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[25D4:2060][2016-04-17T16:09:00]i299: Plan complete, result: 0x0
[25D4:0988][2016-04-17T16:09:00]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
[25D4:0988][2016-04-17T16:09:00]i000: ** MBA ** Getting window handle.
[25D4:0988][2016-04-17T16:09:00]i000: ** MBA ** Calling Engine.Apply(). Window handle: 917904
[25D4:2060][2016-04-17T16:09:00]i300: Apply begin
[288C:20EC][2016-04-17T16:09:00]i000: Caching bundle from: 'C:\Users\Richard\AppData\Local\Temp\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\.be\SetupChipset.exe' to: 'C:\ProgramData\Package Cache\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\SetupChipset.exe'
[288C:20EC][2016-04-17T16:09:00]i320...
AlHill
Updating the chipset inf will not help you.
It is likely that your graphics are not supported on Windows 10, and that you are using the Microsoft generic driver.
Provide your processor model and graphics,
In the meantime, review http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products to see if your graphics are supported.
Doc
AW
Thanks for the quick response,
Processor: Celeron(R) Dual-Core CPU T3500 2.10GHz 2.10GHz
I couldn't find my processor on the link you provided.
AlHill
I do not see that the T3500 has graphics support: http://ark.intel.com/products/42104/Intel-Celeron-Processor-T3500-1M-Cache-2_10-GHz-800-MHz-FSB?q=T3500 Intel® Celeron® Processor T3500 (1M Cache, 2.10 GHz, 800 MHz FSB) Specifications
What is the manufacturer/model of your PC/laptop?
Doc
AW
Manufacturer- Hewlett Packard
Model- HP G56 Notebook PC
AlHill
Ok, there are going to be some xxxx info on the HP G56 Notebook PC. Look on the bottom for something like G56-xxxxx.
Or, run DXDIAG and provide the "device" info on the display tab.
There are multiple models of this notebook, and multiple graphics chipsets.
Doc
AW
I hope this provides you with the information you need.
AlHill
Yes. Unfortunately, the Intel Mobile 4 Series chipset is not supported on Windows 10, as you can see in the link I provided under "Legacy graphics products"::
Doc
AW
I see, thanks a lot for the help. Would you recommend downgrading, or is it possible to go around this problem by doing something like installing something that is compatible?
Hi AliceinMalice123,
I suggest you to uninstall and delete the current graphics driver from device manager. Restart the system and run Windows® 10 update.
Mike C
I am following your case. Let me know if you need further assistance.
Mike C
