23806 Discussions
Any one help me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MShan4
This is ma Graphics Produc Intel®G33/G31 And ma motherboard model is AAD81072-305 is tht possible to upgrade graphics slot
AlHill
No, it is not possible to update the graphics.
Doc
MShan4
But sir i have option to insert in ma motherboard
AlHill
The graphics chipset cannot be changed, replaced, or updated.
However, if you have an available slot, you can insert a graphics card of your choosing.
Depending on the motherboard, inserting a graphics card will likely disable the onboard graphics chipset (especially with a chipset this old).
And, with a board this old, inserting a "new" graphics card is likely to have a compatibility problem.
Personally, I would get a new motherboard.
Doc
MShan4
sir can you please see this one it shows supported
http://ark.intel.com/products/31914/Intel-82G33-Graphics-and-Memory-Controller Intel® G33 Express Chipset (Intel® 82G33 Graphics and Memory Controller) Specifications
AlHill
If you want to update the graphics driver, that is a different issue. What operating system are you using?
Doc
AlHill
The G33/G31 chipset is not supported on Windows 8, 8.1, or 10: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
As far as the graphics card, I cannot confirm that it will work on your PC.
Doc
Hi Murale Shanakar,
Your board is old now, it has PCIe revision 1.1, it will be difficult to find a compatible card. The latest units require PCIe 3.0. Also, as Al Hill said, the board is out of support, so there are no drivers available for the latest operating systems.
http://ark.intel.com/products/31914 http://ark.intel.com/products/31914
Mike C
Hi Murale Shanakar,
I am following your case. Let me know if you need further assistance.
Mike C
