23660 Discussions
How to Fix Intel HD Graphics Driver mismatch 4400 (version 10.18.14.4280) in Windows 8.1 joined to an Active Directory domain controller?
JFern22
I have computers running Windows 8.1 Pro entered in an Active Directory domain controller.
The machine wallpaper is only in black.
At first I thought it was some Active Directory configuration, but when uninstalled the video driver wallpaper reappeared, but when I restarted the machine the wallpaper is all black.
This problem only occurs in Windows 8.1 with this video driver.
Any suggestions how to fix this problem?
IUman
Could you please reply with your system model and processor model?
Please try uninstalling the driver and then reinstalling it and after that reboot your system.
Could you please provide us with your graphics report?
Go to Intel® Graphics and Control Panel > Options > information Center > Save.
Also, I will appreciate if you can post the msinfo32.
  1. Please press Windows Key + R to open the Run Menu
  2. Type msinfo32 and click OK
  3. While viewing the System Summary node go to File then Save (Please do not use Export)
  4. Save your MSINFO32 report as msinfo32.nfo on your desktop for easy access and then you can post it here.
Regards!
Ivan
JFern22
Ivan,
I've done the driver installation
When did I reinstall the wallpaper set on the GPO appeared, but after rebooting the computer he returned to turn black.
Below are the msinfo information.
Microsoft Windows Operating System name 8.1 Pro
Version 6.3.9600 Build 9600
Another description of the operating system not available
Manufacturer Operating System Microsoft Corporation
System name AT002
System manufacturer Dell Inc.
System Model OptiPlex 3030 AIO
PC type system based on X64
System SKU 0623
Intel (R) Core (TM) CPU @ 3.00GHz i5-4590S, 3001 Mhz, 4 core (s), 4 processor (s) course (s)
Version / Date BIOS Dell Inc. A06, 04/08/2015
SMBIOS version 2.7
Version of Embedded Controller 255255
BIOS so Inherited
Manufacturer of the base-plate Dell Inc.
Model baseboard Not available
Baseboard name plate Base
Function Platform Desktop
State of the Safe Boot Unsupported
Setting PCR7 connection Impossible
Windows C: \ Windows
The system folder C: \ Windows \ system32
Boot Device \ Device \ HarddiskVolume1
Location Brazil
Hardware Abstraction Layer Version = "6.3.9600.17196"
Username cherry \ at002.credisisleste
Time zone Caracas Standard Time
Physical memory (RAM) installed 8.00 GB
Total Physical Memory 7.92 GB
Available physical memory 5.31 GB
Total Virtual Memory 9.17 GB
Available Virtual Memory 6.58 GB
1.25 GB of paging file space
Pagefile C: \ pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Address Translation Extensions Second Level Yes
Hyper-V - Enabled Virtualization in Firmware Yes
Hyper-V - Execution Yes Data Protection
As for the graphics reports could not find the option to generate the report.
IUman
I appreciate you have replied with that information, from my we have not seen similar issues like this or other customers experiencing this issue.
Have you tried contacting Microsoft to see if they can help you with this issue?
One question, are you using Hyper-V for the virtual machine?
From my end what I can do is to escalate this case to find out if there is a way we can help you.
Regards!
Ivan
JFern22
Ivan,
I opened a case on the Microsoft TechNet, but the solutions did not correct the problem reported.
As I told you, I think that is any inconsistency with this driver because Windows 7 wallpaper is applied usually only on Windows 8.1 Pro with the Intel driver you are experiencing these problems.
IUman
I'm sorry but I still don't understand if the black screen that you get is in your computer or a virtual machine that you're using?
Do you get an error code?
JFern22
Let me try to explain better.
I have an Active Directory server installed in our company.
This machine is having problems is not a virtual machine, it is a physical workstation. She is applying the GPO's Domain normally, but the bottom GPO wallpaper does not appear, it is a part of all black wall. So when I uninstalled the driver, or updated, the wallpaper I set the GPO appeared that workstation, but when I restart the machine will become a black wallpaper.
This only happens on Windows 8.1 Pro with Intel this driver, so my suspicion as to compatibility issues with this driver
IUman
Please let me do some more research about this issue and if I find a solution I will post it here.
The Intel® graphics driver that you have installed was downloaded from the Intel website or it is the one provided by your computer manufacturer, if yes, have you tried reinstalling the one from your computer manufacturer to see if that can help you any better?
