23076 Discussions
How to disable certain hot key in GMA control panel?
Is it possible to disable only one specific hot key in the Hot Key Manager in GMA control panel? I only see Enable checkbox on top but this turns off all hotkeys. I tried pressing backspace or delete key but this doesn't disable key combination. I want to prevent myself from accidentaly rotating my screen. I do use panel fitting hotkey a lot, so disabling all hotkeys is not a good solution.
Thanks!
