23068 Discussions
How to extract gfx_win_101.4314.exe with command line
Vi99
I am doing a deployment of gfx_win_101.4314.exe from Intune.
When running with Intune the extraction goes automatically to System folder, and Intel driver is getting block with error message " The application is in an unauthorized location. Please move to a non-system folder".
I would like to know what is the switches or parameters I can use in my cmd to change the location of extraction.
I have tried different switches but non of them work:
-a -p
-e -d
Could you let me know how to extract in a specific place during install ?
Thank you,
DeividA_Intel
Hello Vi99,
Thanks for your patience. I can recommend you try the following steps:
  1. Open Windows Settings.
  2. Select System.
  3. Click Advanced system settings.
  4. In the pop-up Windows Properties window, select Advanced.
  5. Click Environment Variables.
  6. Change TMP under User variables for USER to %USERPROFILE%\AppData\Local\Temp.
  7. Change TEMP under User variables for USER to %USERPROFILE%\AppData\Local\Temp.
  8. Click OK to save and close the Environment Variables window.
  9. Click OK to save and closeWindows Properties window.
If this did not help, I recommend you to check this request with Microsoft, since they will have more information related to the command prompt.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Hugo_Intel
Hello Vi99
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues trying to o a deployment of the graphics driver.
Allow me to check if there is any information we can provide on this topic, since this is a Microsoft app/feature we cannot make any guarantees. I will post back once I have an update for you.
Hugo O.
DeividA_Intel
Hello Vi99,
  2. Select System.
Deivid A.
Hugo_Intel
Hello Vi99
I see this thread has been marked as resolved and we are glad the information helped. Since the issue was solved we will be closing this thread. feel free to open a new topic if you need further assistance.
Hugo O.
