23586 Discussions
How to fix windows 8.1 32bit display adapter problem
CKyle2
Whenever i install the update for the display adapter which is intel hd graphics i get a double and blurry screen with a vertical lines​ but when i uninstall or disable the graphic driver it comes back to normal using windows basic display adapter 20200404_005757.jpg20200404_010309.jpg20200404_005832.jpg20200403_224925.jpg
AlHill
What is the model number of your processor?
What is the model number of your laptop or desktop?
Doc
CKyle2
Processor: Intel(R) Pentium(R) CPU 987 @ 1.50GHz 1.50 GHz
Laptop: Acer Aspire V5-431P-987B4G50MASS
AlHill
Your processor is from 2012.
The latest driver (from 2015) can be found here:
https://downloadcenter.intel.com/download/24970?product=67194
Doc
CKyle2
i think that using that latest driver is the problem because if im updating to it it creates that screen but using the windows basic display adapter, theres no problem i
AlHill
I see from the acer support page for your laptop that only 64-bit W8.1 is supported.
Is there a reason you are running 32-bit?
If you can get to 64-bit, then try the intel driver on the acer page:
https://www.acer.com/ac/en/US/content/support-product/4610?b=1
Doc
CKyle2
AlHill
You are using W8.1 32-bit. Did you purchase this laptop new, and was this the OS on it when purchased?
Doc
CKyle2
no i did not buy it new it was from my brother before broke because of overheating and given to me last 2016 i didnt open it up until now
AlHill
Ok, so it was like this when you purchased it, correct?
Is there a Microsoft key on a sticker on the bottom of the laptop? Do not provide the key, or a photo - that would be bad. If there is a sticker, does it say W8.1 64-bit Pro on it?
Doc
CKyle2
yes its already like this after the repair
CKyle2
AlHill
Ok, but what does the sticker say (do not provide the key)?
Doc
AlHill
Neither. There should be a MICROSOFT product KEY with other information.
It sounds to me like the repair should may have done you an injustice, by not installing what was was part of the original install.
If you do not see a Microsoft product key sticker, remove and look under the battery. If you do not find it there, that makes things more difficult.
Doc
CKyle2
Nope Nothing Even The Battery Itself Has No Product Key
AlHill
Well, from your laptop support page, it appears you should be 64-bit.
When you say "like this after the repair", did the graphics work before the repair?
Have you tried contacting Acer for support?
Doc
CKyle2
Yes it worked great before the repair..my brother could play games which caused the overheating but 2 or 5 days after the repair The Screen Became Like this
AlHill
I do not know that there is much I can do for you.
You may be experiencing hardware failure.
You may try force installing the 32-bit driver from here:
Here are the instructions on how to do so:
https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Or, perhaps one of the Intel support engineers can assist you.
Or, with a laptop this old, you may want to consider new(er) hardware.
Doc
CKyle2
thanks for the help man i really appreciate it and i have a newer laptop but it would be a waste to throw this besides i like repairing stuffs like this for the sake of learning 🙂
