22923 Discussions
How to obtain 5K resolutions
TNguy211
You previously stated that "Regarding 5K resolutions ... it usually requires two DisplayPort* connections to achieve this resolution."
i'm not sure how that works? My monitor has hte one DisplayPort connection and i've put it to a graphics card through a DisplayPort 1.4 cable.
If you can elaborate that would be appreciated.
AlHill
What processor model number?
What operating system? Windows 10? Which version? 1903?
What motherboard/device? Provide the model number and manufacturer.
Doc
TNguy211
Hi Doc, I have a mother board ASUS z97-A with intel hd graphics 4600 that came with the motherboard. Chipset Inter Core i7- 4790k CPU @ 4.00GHz. Using Gigabyte NVIDIA GeForce Low Profile GTX 1050 OC 2GB Gaming Graphics Video Card windows 10 Home - Version 1903 (OS Build 18362.239). ---- On Fri, 26 Jul 2019 05:01:12 +1000 Intel Forums <mailto:supportreplies@intel.com> wrote ---- What processor model number? What operating system? Windows 10? Which version? 1903? What motherboard/device? Provide the model number and manufacturer.   Doc             https://forums.intel.com/0050P00000896au?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931   https://forums.intel.com/0050P00000896au?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931 (Customer) What processor model number? What operating system? Windows 10? Which version? 1903? What motherboard/device? Provide the model number and manufacturer.   Doc     https://forums.intel.com/0D70P000006RBhs?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931   or reply to this email             Replying to     https://forums.intel.com/0050P000008W2Ng?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931   https://forums.intel.com/0050P000008W2Ng?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931 (Customer) asked a question. https://forums.intel.com/0D50P00004OwwWK?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931&OpenCommentForEdit=1 How to obtain 5K resolutions Hi,   You previously stated that "Regarding 5K resolutions ... it usually requires two DisplayPort* connections to achieve this resolution."   i'm not sure how that works? My monitor has hte one DisplayPort connection and i've put it to a graphics card through a DisplayPort 1.4 cable.   If you can elaborate that would be appreciated.             https://forums.intel.com/0050P00000896au?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931   https://forums.intel.com/0050P00000896au?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931 (Customer) What processor model number? What operating system? Windows 10? Which version? 1903? What motherboard/device? Provide the model number and manufacturer.   Doc   https://forums.intel.com/0D70P000006RBhs?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931               You're receiving emails when someone "Comments on my posts."   To change or turn off Forums email, https://forums.intel.com/_ui/core/feeds/notification/ChatterEmailSettings?setupid=CollaborationEmailSettings&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008W2Ng&s1ext=0&emkind=chatterCommentNotification&emtm=1564081272931 as mailto:300002259926@intel.com.isvc.   Are notifications about this post getting annoying? Reply to this email with the word " mute ".   For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html.
Leonardo_C_Intel
Hello TNguy211
Thank you for posting in the Intel Community.
The Intel® HD graphics can handle two 4k outputs with a Display Port (DP) 1.2 but to handle the 5K resolution the display has to be able to handle two DP port input and be able to handle the resolution.
Leonardo C.
A Contingent Worker at Intel
TNguy211
Thanks Leonardo,
I'm a little confused.
I have an Intel hd graphics 4600 and that only has one DisplayPort port. My LG monitor 34WK95U-W one has one DisplayPort port for one DP cable. So i'm not sure how my intel graphics can even enable two DP port inputs?
Can you clarify please?
Leonardo_C_Intel
Hello TNguy211
The Intel® Core™ i7-4790K Processor (https://ark.intel.com/content/www/us/en/ark/products/80807/intel-core-i7-4790k-processor-8m-cache-up-to-4-40-ghz.html)
has the capability to use the following Video outputs:
Max Resolution (HDMI 1.4):3840x2160@24Hz
Max Resolution (DP): 3840x2160@60Hz
Max Resolution (eDP -Integrated Flat Panel) 3840x2160@60Hz
Max Resolution (VGA): 1920x1200@60Hz
You can see that the processor
can handle two 4k video outputs
In your case since the
motherboard and display only have one DP port on each your hardware set up will
not let you set the 5K resolution.
Leonardo C.
TNguy211
Thanks Leonardo. That make sense now. Cheers
