23823 Discussions
How to switch color profiles?
I have defined two separate color profiles under the Intel HD Graphics settings ... one for video viewing and one for PC word processing.
How can I switch between them using a hotkey ... or a script ... or some other command?
Thanks for any help.
DArce
Valued Contributor III
The option would be selecting the respective profile through a right click on the desktop and launch it from the profile menu shown there. Basically right click> Graphics options > Profiles > Display Profiles > "Your profile"
For more information on Display profiles option you can check this article:
http://www.intel.com/support/graphics/sb/CS-028686.htm# Profiles http://www.intel.com/support/graphics/sb/CS-028686.htm# Profiles
Thanks for your response. Yes, I know that method. But, actually, that wasn't my question:
Are you saying there is NO WAY to switch, otherwise?
Since the methods I listed are commonly used for this kind of thing, can my request be passed to the driver support team for their assessment?
(BTW: other Internet sources list a command line entry of the form \igfxcfg.exe\SchemeName: for controllers a couple of years back. Mine is a new HD Graphics 3000.)
DArce
In the current user interface the option would be just through the method I mentioned, however let me confirm if these capabilities you mentioned would be still applicable.
