23278 Discussions
How to use Combined Monitors (Collage) ?
Adrian_Vasile_C_
Hello
I have an Arc A770 LE with two FHD monitors, connected over DP and HDMI. I also have an UHD 770 iGPU (13900K) with no monitors connected.
How do I use combined monitors (collage) please ? There is no such option for me in either Arc Control or the Graphics Command Center applications.
I have other discrete GPUs that have the option (the AMD Eyefinity and NVIDIA Surround), but Intel Arc can not do this ? Why ?
Can Intel implement the missing option please ?
Thank you,
Adrian Constantin
Andres_Intel
Hello Adrian_Vasile_C_,
Thank you for posting on the Intel®️ communities. I see that you are having issues using collage mode with your Intel® Arc™ A770 Graphics, I understand how important is this for you, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Adrian_Vasile_C_
Hello
My 2 monitors are as follows:
  • Philips 227E6 (connected over HDMI cable)
  • Philips 241B7Q (connected over DisplayPort cable)
Both monitors have the same resolution: 1920x1080 (FHD), both running at 60 Hertz
I have attached here the SSU logs as instructed.
Thank you,
Adrian Constantin
Andres_Intel
Thank you for your response, all the information provided has been really helpful.
I will start with an investigation to provide you with the next steps, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Thank you for your time.
I have been working on the investigation of your issue, to enable Combined Desktop (Collage) you need at least 2 displays with the same physical dimensions and native timings (resolution, refresh rate) and use Intel® Graphics Command Center (Beta). You can see the following video for guidance.
Let me know if you have further questions.
Andres P.
Adrian_Vasile_C_
Is it necessary to REQUIRE the same physical dimensions for the monitors ? Can Intel update the Command Center to show a warning in this case, but allow combining the monitors ?
I obviously see the monitors have different sizes, and there is gonna be a (double) bezel between the monitors any way.
It hardly seems fair that I should buy a new monitor, to work around an artificial limitation for this issue...
Andres_Intel
Were you able to watch the video and download Intel® Graphics Command Center (Beta)?
Andres P.
Andres_Intel
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Intel Customer Support Technician
