23279 Discussions
Huge drop in fps while playing world of warcraft (on HD 4000)
I recently bought a new laptop mainly to play World of Warcraft while on the move (have to travel quite a bit for work), and picked the Samsung model which was quite recommended (as per its reviews) for gaming.
Here's a rundown of specs from dxDiag.
System Information
Time of this report: 11/12/2012, 10:05:21
Machine name: CHARLIE
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: 550P5C/550P7C
BIOS: AMIBIOS Version P06AAA.043.120925.dg
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz (8 CPUs), ~2.3GHz
Memory: 8192MB RAM
Available OS Memory: 8090MB RAM
Page File: 3802MB used, 12374MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_C0D1144D&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC314B
Native Mode: 1600 x 900(p) (60.115Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2875 (English)
Driver Version: 9.17.10.2875
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2012 17:40:22, 12615168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-C67C-DBE0B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0xC0D1144D
Revision ID: 0x0009
Driver Strong Name: oem8.inf:Intel.Mfg.NTamd64:iIVBM0:9.17.10.2875:pci\ven_8086&dev_0166
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Please do note that the laptop comes with 2 graphic adapters the Intel on board one, + an nVidia GT650M.
When I first started playing WoW, the game was running between 80-120 fps at maximum settings, now after doing several system updates, including all drivers/samsung/AV etc...whenever I play WoW it's a hit and miss situation.
The game either runs smoothly like before, or barely goes above 10 fps on lowest graphics settings.
It has become very annoying, and I honestly have no clue what might be causing this. Sometimes reboot solves the issue, other times 10 reboots don't do anything.
Any help is much appreciated.
Hi Nic and thanks for looking into it but sadly that did not do the trick
For now am thinking of doing a full system restore from the CD that came with it, then go on updating stuff step by step.
But I would really love not to have to do this if it's possible
Just yesterday, while in the middle of the game, I logged out then back in on another character, and the fps jumped back to normal. So am kinda sure it's not related to rebooting the machine. It's really weird,
