23796 Discussions
I am having problems with the Intel Graphics HD installation with Dell 3147.
WChin8
The latest graphics driver cannot install due to incompatible device detected. I have a Dell 3147 and it is not installing the driver.
Any help would be appreciated.
William
AlHill
Have you contacted Dell for support of THEIR device?
Doc
n_scott_pearson
I believe that this issue is the result of attempting to install the standard driver from Intel onto a system that utilizes a modified version of this driver. For laptops, unless the vendor has told you otherwise, you must use *only* the versions of the driver provided by this vendor. Regardless, the vendor is responsible for the support of this situation. Please contact them.
,,,S
