23272 Discussions
I can't find the "Customize Aspect Ratio" button in Intel® HD Graphics Control Panel
壓力傷大
Wanner_G_Intel
Hello 壓力傷大, Thank you for joining this Intel Community. Modifying the Aspect Ratio was possible with older driver versions. However, if you are running Windows* DCH drivers, modifying the Aspect Ratio from the Graphics Control Panel may not be possible. To continue troubleshooting this issue, please run the Intel® System Support Utility and attach the report to this thread to take a look at your system configuration. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
