22881 Discussions
I can't update my GPU. What to do?
JGumb
what is the meaning of this ?
[10C4:18B8][2015-11-02T05:03:21]i001: Burn v3.9.1208.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\admin\Downloads\Intel Driver Update Utility Installer.exe, cmdline: ''
[10C4:18B8][2015-11-02T05:03:21]i000: Initializing numeric variable 'DCAOPTIN_Checkbox' to value '0'
[10C4:18B8][2015-11-02T05:03:21]i000: Initializing string variable 'LaunchTarget' to value '[ProgramFilesFolder]Intel Driver Update Utility\DriverUpdateUI.exe'
[10C4:18B8][2015-11-02T05:03:22]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\admin\AppData\Local\Temp\Intel_Driver_Update_Utility_20151102050322.log'
[10C4:18B8][2015-11-02T05:03:22]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\admin\Downloads\Intel Driver Update Utility Installer.exe'
[10C4:18B8][2015-11-02T05:03:22]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\admin\Downloads\'
[10C4:18B8][2015-11-02T05:03:22]i000: Setting string variable 'WixBundleName' to value 'Intel Driver Update Utility'
[10C4:197C][2015-11-02T05:03:22]i000: Setting version variable 'WixBundleFileVersion' to value '2.2.0.5'
[10C4:18B8][2015-11-02T05:03:22]i100: Detect begin, 2 packages
[10C4:18B8][2015-11-02T05:03:22]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full'
[10C4:18B8][2015-11-02T05:03:22]i052: Condition 'NETFRAMEWORK45 >= 378389' evaluates to false.
[10C4:18B8][2015-11-02T05:03:22]i101: Detected package: NetFx45Web, state: Absent, cached: None
[10C4:18B8][2015-11-02T05:03:22]i101: Detected package: DriverUpdateUtilityInstaller, state: Absent, cached: Complete
[10C4:18B8][2015-11-02T05:03:22]i199: Detect complete, result: 0x0
[10C4:197C][2015-11-02T05:03:37]i000: Setting numeric variable 'DCAOPTIN_Checkbox' to value 1
[10C4:197C][2015-11-02T05:03:39]i000: Setting numeric variable 'DCAOPTIN_Checkbox' to value 1
[10C4:18B8][2015-11-02T05:03:39]i200: Plan begin, 2 packages, action: Install
[10C4:18B8][2015-11-02T05:03:39]w321: Skipping dependency registration on package with no dependency providers: NetFx45Web
[10C4:18B8][2015-11-02T05:03:39]i000: Setting string variable 'NetFx45FullWebLog' to value 'C:\Users\admin\AppData\Local\Temp\Intel_Driver_Update_Utility_20151102050322_0_NetFx45Web.log'
[10C4:18B8][2015-11-02T05:03:39]i000: Setting string variable 'WixBundleRollbackLog_DriverUpdateUtilityInstaller' to value 'C:\Users\admin\AppData\Local\Temp\Intel_Driver_Update_Utility_20151102050322_1_DriverUpdateUtilityInstaller_rollback.log'
[10C4:18B8][2015-11-02T05:03:39]i000: Setting string variable 'WixBundleLog_DriverUpdateUtilityInstaller' to value 'C:\Users\admin\AppData\Local\Temp\Intel_Driver_Update_Utility_20151102050322_1_DriverUpdateUtilityInstaller.log'
[10C4:18B8][2015-11-02T05:03:39]i201: Planned package: NetFx45Web, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[10C4:18B8][2015-11-02T05:03:39]i201: Planned package: DriverUpdateUtilityInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[10C4:18B8][2015-11-02T05:03:39]i299: Plan complete, result: 0x0
[10C4:18B8][2015-11-02T05:03:39]i300: Apply begin
[1A7C:1DF0][2015-11-02T05:03:42]i360: Creating a system restore point.
[1A7C:1DF0][2015-11-02T05:03:58]i361: Created a system restore point.
[1A7C:1DF0][2015-11-02T05:03:58]i000: Caching bundle from: 'C:\Users\admin\AppData\Local\Temp\{fe92d390-13ee-4660-a2f8-39a066fdffe0}\.be\Intel Driver Update Utility Installer.exe' to: 'C:\ProgramData\Package Cache\{fe92d390-13ee-4660-a2f8-39a066fdffe0}\Intel Driver Update Utility Installer.exe'
[1A7C:1DF0][2015-11-02T05:03:58]i320: Registering bundle dependency provider: {fe92d390-13ee-4660-a2f8-39a066fdffe0}, version: 2.2.0.5
[10C4:1A10][2015-11-02T05:03:58]w343: Prompt for source of package: NetFx45Web, payload: NetFx45Web, path: C:\Users\admin\Downloads\redist\dotNetFx45_Full_setup.exe
[10C4:1A10][2015-11-02T05:03:58]i338: Acquiring package: NetFx45Web, payload: NetFx45Web, download from: http://go.microsoft.com/fwlink/?LinkId=225704 http://go.microsoft.com/fwlink/?LinkId=225704
[1A7C:1AD0][2015-11-02T05:04:05]i305: Verified acquired payload: NetFx45Web at path: C:\ProgramData\Package Cache\.unverified\NetFx45Web, moving to: C:\ProgramData\Package Cache\F6BA6F03C65C3996A258F58324A917463B2D6FF4\redist\dotNetFx45_Full_setup.exe.
[1A7C:1AD0][2015-11-02T05:04:06]i304: Verified existing payload: DriverUpdateUtilityInstaller at path: C:\ProgramData\Package Cache\{C4FB3CF4-C845-4746-A9F5-476908266433}v2.2.0.1\Intel Driver Update Utility Installer.msi.
[1A7C:1DF0][2015-11-02T05:04:06]i301: Applying execute package: NetFx45Web, action: Install, path: C:\ProgramData\Package Cache\F6BA6F03C65C3996A258F58324A917463B2D6FF4\redist\dotNetFx45_Full_setup.exe, arguments: '"C:\ProgramData\Package Cache\F6BA6F03C65C3996A258F58324A917463B2D6FF4\redist\dotNetFx45_Full_setup.exe" /q /norestart /ChainingPackage "Intel Driver Update Utility" /log "C:\Users\admin\AppData\Local\Temp\Intel_Driver_Update_Utility_20151102050322_0_NetFx45Web.log.html"'
[1A7C:1DF0][2015-11-02T05:08:18]e000: Error 0x80070643: Process returned error: 0x80070643
[1A7C:1DF0][2015-11-02T05:08:18]e000: Error 0x80070643: Failed to execute EXE package.
[10C4:18B8][2015-11-02T05:08:18]e000: Error 0x80070643: Failed to configure per-machine EXE package.
[10C4:18B8][2015-11-02T05:08:18]i319: Applied execute package: NetFx45Web, result: 0x80070643, restart: None
[10C4:18B8][2015-11-02T05:08:18]e000: Error 0x80070643: Failed to execute EXE package.
[1A7C:1DF0][2015-11-02T05:08:18]i351: Removing cached package: NetFx45Web, from path: C:\ProgramData\Package Cache\F6BA6F03C65C3996A258F58324A917463B2D6FF4\
[1A7C:1DF0][2015-11-02T05:08:18]i330: Removed bundle dependency provider: {fe92d390-13ee-4660-a2f8-39a066fdffe0}
[1A7C:1DF0][2015-11-02T05:08:18]i352: Removing cached bundle: {fe92d390-13ee-4660-a2f8-39a066fdffe0}, from path: C:\ProgramData\Package Cache\{fe92d390-13ee-4660-a2f8-39a066fdffe0}\
[10C4:18B8][2015-11-02T05:08:18]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
marun
The product number I am looking for is the product number for your notebook. http://www.traininginsholinganallur.in/informatica-training-in-chennai.html This link will show you were to find it and give you an example of what it looks like. As for the game settings I would suggest increasing your brightness to see if that helps. This game is still in it's early access phrase with the full release coming out in at the end of August so there are still making some changes to the game. On a personal note that game looks just like the kind of game I get into. I am going to check out it http://www.traininginsholinganallur.in/informatica-training-in-chennai.html myself.
Allan_J_Intel1
I would need more information in regards to your system configuration:
Which version of Windows do you have?
Also, the exact processor model and the graphics controller:
http://www.intel.com/support/graphics/sb/CS-009482.htm Graphics Drivers — How to Identify Your Intel® Graphics Controller
Click the Windows icon, and then right-click Computer .
Select Properties .
Find System Type on the Properties window, and then note the processor model.
Allan.
AP16
Valued Contributor III
Allan_J_Intel1
@jeb_gumban
Were you able to get product information?
Allan.
