22748 Discussions
I can't update my Intel HD Graphics 4000 graphics driver
CMuji1
Hi, I have a Toshiba Satellite S845-SP4336TL, and its customized Toshiba graphics driver is quite outdated, so I decided to manually install the generic one from the Intel download center, but when I'm going to install it a message appears saying that I already have the latest version installed, which isn't true. What should I do? Do I have to keep waiting for Toshiba to release an update? Because it's been almost two years
Allan_J_Intel1
Try to force the installation of Intel generic drivers by performing manual procedure, see here for instructions:
http://www.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer Manufacturer Graphics Driver Detected
Select your operating system version and download the zip version of the video driver:
https://downloadcenter.intel.com/search?keyword=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000 Intel® Download Center
When installing generic drivers, know that all graphics features available for your graphics controller may not be available.
Allan.
CMuji1
That's exactly what I tried to do, to manually install the driver, but when I select the folder where I unzipped the files, a message appears saying that I already have the latest version installed, which is false because I have the 10.x version and the latest one is 15.x
Allan_J_Intel1
Attach the graphics report found on the graphics control panel.
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
Allan.
CMuji1
Here it is:
Intel(R) HD Graphics 4000
Report Date: 7/26/2015
Report Time[hh:mm:ss]: 00:00:28
Driver Version: 10.18.10.3345
Operating System: Microsoft Windows 8.1 Single Language(6.3.9600)
Default Language: Spanish (Chile)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 8091 MB
Processor: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Processor Speed: 2494 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Connector Type: LVDS
Serial Number: LGD033C
Gamma: 2,2
DDC2 Protocol: Supported
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 12,20 inches
Vertical: 06,69 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 3C 03 00 00 00 00
00 16 01 03 80 1F 11 78 0A A9 25 96 58 57 8E 28
1F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 46 1E 56 C8 50 00 38 30 24 30
35 00 35 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 34 2D 54 4C 4E 31 00 DD
* Other names and brands are the property of their respective owners. *
Allan_J_Intel1
It seems that you need to wait for customized drivers provided by Toshiba.
http://support.toshiba.com/ http://support.toshiba.com/
Allan.
CMuji1
Aaaww Thanks for your time Allan.
KRodr2
I've been having the same problem. Can someone help here please?
