23525 Discussions
I cannot set 3440x1440 resolution (UHD 620 - ASUS UX333)
Francoise
I don't succeed to have have max resolution 3440x1440 , only 1920x1080 is display in the list.
My configuration is :
ASUS ZenBook UX333FA
HDMI 1.4
Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz 1.80 GHz
UHD Graphics 620
Driver version : 31.0.101.2137
Screen : Viewsonic VA3420C (max resolution 3440 x 1440 - 120hz)
I connect the screen to  PC with a HDMI cable.
I run Intel SSU but don't  know how to use information
I'm on Windows 11
I tried to add manually a custom resolution (3440 x 1440 - 60hz) from Intel control panel, but didn't succeed.
Thank your for your help.
MUC
Honored Contributor I
ViewSonic VA3420C
Supported modes are listed on page 31
  • 1 x DisplayPort 1.2 HBR2
  • 2 x HDMI 2.0 TMDS (600 MHz)
  • 1 x USB-C with DisplayPort 1.2 HBR2
ASUS Zenbook 13 UX333
1 x HDMI 1.4 (300 MHz)
This is a Coffee Lake (8th Gen) platform. In this case, the HDMI output is only designed for up to 300 MHz TMDS. The HDMI output is also the only video output on this laptop.
If we assume that the monitor uses VESA Coordinated Video Timing - Reduced Blanking (CVT-RB), then:
3440 x 1440 @ 60 Hz = 319.75 MHz TMDS
Unfortunately, the laptop cannot support this.
To see what is possible, please run edid-test.exe:
https://www.monitortests.com/edid-test.zip
This will create a file named "edid-test.txt" in the same folder. Please attach this TXT file here.
