23105 Discussions
I cant update my drivers manually and intel utility
JOrla1
to try to manually install appears the error box: The driver installed is not validated for this computer.
and for the Utility app appears: No drivers for your product
How can I fix it and install the latest drivers?
Amy_C_Intel
Hello AnunnakiRamb0,
That message indicates that your computer manufacturer does not allow the installation of generic Intel video drives. You are required to install drivers from your computer manufacturer, however, you may try forcing the installation of Intel generic drivers by performing manual procedure, see here for instructions:
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1* and download the driver from https://downloadcenter.intel.com/ Intel® Download Center filter according to your system configuration.
For further reference http://www.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Error Message: Computer Manufacturer Graphics Driver Detected.
Amy.
JOrla1
one more question, u guys from Intel are working to fix it or make it more easy? This had never happened app does not work and now with Windows 10 blocking generic drivers is complicated.
Amy_C_Intel
I understand your situation but this matter is completely related to your computer manufacturer. It is possible that your systems needs a customized driver according to each feature present on your system and the computer manufacturer may impose restrictions when installing generic Intel(R) drivers.
Amy.
